主题:针尖的弹性系数
浏览0 回复3 电梯直达
iceriver_99
用tapping模式,用悬臂调节可以确定针尖的弹性系数,但是转到contact模式下,弹性系数还是那个数值,又不能调节,怎么来确定呢?大概在什么范围内?会不会影响成像质量?
清风侠
原文由 iceriver_99 发表:
每个针尖都有一个参考的弹性系数,轻敲模式下测量的弹性系数也是不准确的。对要求不是特别高的研究实验来说(比如说仅仅成像的话,影响不大,但是如果计算相互作用力,影响较大),可以不特别考虑弹性系数!
jixiangcao
我做实验的时候发现,有时是由影响的,但是如果在tapping模式下图象良好,直接转换到contact模式不用调节参数,对图像不造成影响
Hansen
contact mode probe need low spring constant to allow cantilever defleted easily. it mean lower force on surface.
Tapping mode probe need high spring constant to allow resonant vibration easily.
If you use Tapping mode probe for contact mode operation, the speing constant will be too high and destroy tip or sample easily. But it is good for you to do mechanical lithography.
If you use Contact mode probe to do Tapping moder operation, the spring constant is too low and it will give you a lower resonant frequency. From experience, it is unstable.But Tapping in fluid operation must use low spring constant probe.
You can fo to web site below to see frequency effect.
  http://www.tbcl.com.tw/Product/SPM/SPM.htm
手机版: 针尖的弹性系数
