最近见到几个网友提的一些有关温度控制方面的问题和实验要求,感觉温度控制虽然简单,但是要轻松的实现一些实验室要求,温度控制方面还是有很多值得研究的地方,在这里贴出温度控制顶级仪器公司JULABO列出的一些常见问题及解决方法。了解了这些知识,相信实验室遇到的一般温度方面的问题(不论是温度控制系统建设还是温度控制仪器调试)都能迎刃而解了
第三页有翻译,HOHO
1. What is working temperature range?
Working temperature range is the range within the operating temperature range which can be reached by the circulator itself and without external cooling, based on an ambient temperature of +20 °C.
2. What is operating temperature range?
Operating temperature range is the temperature range limited by the controlelectronics. E.g. working temperature range of heating circulators can be extended by auxiliary means down to the maximum of the lower operating temperature range.
3. What is temperature stability?
Temperature stability is the maximum temperature difference at one specific measuring point in the circulator bath.
4. What is temperature uniformity?
Temperature uniformity is the maximum temperature difference at different measuring points in the circulator bath. This is especially important for calibration tasks . In JULABO circulators tem-perature uniformity differs only slightly from temperature stability. Visco baths and calibration baths offer the best temperature uniformity.
5. What advantages are featured by JULABO displays?
JULABO LED displays are visible at large distances and from every angle.
MULTI-DISPLAY (LED) refers to the possibility of not only displaying actual and setpoint values, but also values for high / low temperature warning and high temperature cut-off.
Additionally the MULTI-DISPLAY (LED) enables the indication of the desired pump stage in circulators with electronically adjustable pumps and the display of the shaking frequency in shaking water baths.
