Polish the glassy carbon electrode with powdered alumina and rinse.
Place the electrode in a bath sonicator and sonicate for 2 minutes. Rinse again thoroughly with DI water.
Check the surface using microscope if available.
This procedure needs to be repeated every time you take a measurement.
