Phase | Composition | max. Temperature [°C] * | Polarity |
OPTIMA® 1 | dimethylpolysiloxane | 340 / 360 | lowest |
OPTIMA® 1 MS | dimethylpolysiloxane with low bleeding | 340 / 360 | |
OPTIMA® 1 MS Accent | dimethylpolysiloxane with ultra-low bleeding | 340 / 360 | |
OPTIMA® 5 | 5 % phenyl – 95 % methylpolysiloxane | 340 / 360 | |
OPTIMA® 5 MS | 5 % diphenyl – 95 % dimethylpolysiloxane with low bleeding | 340 / 360 | |
OPTIMA® 5 MS Accent | silarylene phase with ultra-low bleeding: polarity similar to 5 % diphenyl – 95 % dimethylpolysiloxane | 340 / 360 | |
OPTIMA® 5 HT | cross-linked silarylene phase: polarity index according to 5 % phenyl – 95 % methylpolysiloxane | 380 / 400 | |
OPTIMA® XLB | silarylene phase with ultra-low bleeding: optimized silarylene content | 340 / 360 | |
OPTIMA® δ-3 | autoselective polarity between OPTIMA® 5 and OPTIMA® 1701 | 340 / 360 | |
OPTIMA® δ-6 | autoselective polarity between OPTIMA® 17 and OPTIMA® 210 | 340 / 360 | |
OPTIMA® 1301 | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane | 300 / 320 | |
OPTIMA® 624 | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane | 280 / 300 | |
OPTIMA® 624 LB | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane, low bleed | 280 / 300 | |
OPTIMA® 1701 | 14 % cyanopropylphenyl – 86 % dimethylpolysiloxane | 300 / 320 | |
OPTIMA® 35 MS | silarylene phase with very low bleeding: polarity similar to 35 % diphenyl – 65 % dimethylpolysiloxane | 360 / 370 | |
OPTIMA® 17 | phenylmethylpolysiloxane (50 % phenyl) | 300 / 320 | |
OPTIMA® 17 MS | silarylene phase with very low bleeding: polarity similar to 50 % diphenyl – 50 % dimethylpolysiloxane | 340 / 360 | |
OPTIMA® 210 | trifluoropropylmethylpolysiloxane (50 % trifluoropropyl) | 260 / 280 | |
OPTIMA® 225 | 50 % cyanopropylmethyl – 50 % phenylmethylpolysiloxane | 260 / 280 | |
OPTIMA® 240 | 33 % cyanopropylmethyl – 67 % dimethylpolysiloxane | 260 / 280 | |
OPTIMA® WAX | polyethylene glycol 20000 dalton | 240 / 250 | |
OPTIMA® WAXplus | polyethylene glycol with optimized crosslinking | 260 / 270 | |
OPTIMA® FFAP | polyethylene glycol-2-nitroterephthalate | 250 / 260 | highest |
