橡胶行业国家标准(二)
101 GB/T 6038-1993 橡胶试验胶料的配料、混炼和硫化设备及操作程序 Rubber test mixes--Preparation, mixing and vulcanization--Equipment and procedures
102 GB/T 6326-1994 轮胎术语 Tyre terms
103 GB/T 6327-1996 载重汽车轮胎强度试验放方法 Strength test method for truck and bus tyres
104 GB/T 6757-1986 输送带贮存和搬运通则 Conveyor belts--Guide to storage and handling
105 GB/T 6759-1986 输送带的层间粘合强度测定方法 Conveyor belts--Determination of ply adhesion
106 GB/T 6760-1986 平带的层间粘合强度测定方法 Flat belts--Determination of ply adhesion
107 GB/T 6761-1986 平带全厚度拉伸强度和伸长率测定方法 Flat transmission belting--Test method of full thickness tensile strength and elongation
108 GB/T 7035-1993 轻型载重汽车轮胎高速性能试验方法 转鼓法 High speed performence test for light truck tyres Drum method
109 GB 7037-1992 翻新和修补轮胎(斜交) Retreading and repair of tyres (Diagonal)
110 GB/T 7044-1993 色素炭黑技术条件 Colour black-Specification
111 GB/T 7045-1993 色素炭黑pH值的测定 Colour black--Determination of pH value
112 GB/T 7046-1995 色素炭黑邻苯二甲酸二丁酯吸收值的测定 Colour carbon black--Determination of dibutyl phthalate absorption number
113 GB/T 7047-1993 色素炭黑挥发分含量的测定 Colour black--Determination of volatile content
114 GB/T 7048-1993 色素炭黑黑度的测定 Colour black--Determination of blackness
115 GB/T 7050-1993 色素炭黑着色力的测定 Colour black--Determination of tinting strength
116 GB/T 7052-1995 色素炭黑流动度的测定 Colour carbon black--Determination of flow characteristic
117 GB 7127-1986 汽车液压制动胶管 Rubber hose for automotive hydraulic brake system
118 GB 7128-1986 汽车气压制动胶管 Rubber hose for automotive air brake system
119 GB/T 7129-1986 汽车液压制动胶管内容积膨胀测定方法 Determination of volumetric expansion of rubber hose for automotive hydraulic brake system
120 GB/T 7528-1987 橡胶软管术语 Rubber hose--Glossary of terms
121 GB/T 7535-1996 硫化橡胶分类 分类系统说明 Rubber, vulcarized--Classification--Description of the classification system
122 GB 7542-1987 铁路机车车辆制动用橡胶软管 Rubber brake hoses for railway locomotive and car
123 GB 7543-1996 橡胶医用手套 Rubber surgical gloves
124 GB/T 7755-1987 硫化橡胶透气性的测定 恒容法 Rubber, vulcanized--Determination of permeability to gases--Constant volume method
125 GB/T 7756-1987 硫化橡胶透气性的测定 恒压法 Rubber, vulcanized--Determination of permeability to gases--Constant pressure method
126 GB/T 7757-1993 硫化橡胶或热塑性橡胶压缩应力应变性能的测定 Rubber,vulcanized or thermoplastic--Determination of compression stress-strain properties
127 GB/T 7758-1987 硫化橡胶低温特性的测定 温度回缩法 (TR试验) Rubber, vulcanized--Determination of low temperature characteristics--Temperature-retraction procedure(TR test)
128 GB/T 7759-1996 硫化橡胶、热塑性橡胶 常温、高温和低温下压缩永久变形测定 Rubber, Vulcanized or thermoplastic Determination of compression set at ambient elevated or low temperatures
129 GB/T 7760-1987 硫化橡胶与金属粘合的测定 单板法 Rubber, vlcanized--Determination of adhesion to metal--One-plate method
130 GB/T 7761-1987 橡胶与刚性材料粘合强度的测定 圆锥形件法 Rubber--Determination of adhesion to rigid materials using conical shaped parts
131 GB/T 7762-1987 硫化橡胶耐臭氧老化试验 静态拉伸试验法 Rubber, vulcanized--Resistance to ozone ageing--Static strain test method
132 GB/T 7763-1987 硫化橡胶溶胀指数测定方法 Rubber, vulcanized--Determination method of swelling index
133 GB/T 7764-1987 橡胶鉴定 红外分光光度法 Rubber--Identification--Infrared spectrometric method
134 GB/T 7765-1987 橡胶中铜含量的测定 二乙基二硫代氨基甲酸锌光度法 Rubber--Determination of copper content--Zinc diethyldithiocar bamate photometric method
135 GB/T 7766-1987 硫化橡胶中炭黑含量的测定 硝酸消化法 Rubber, vulcanized--Determination of carbon black content--Nitric acid digestion method
136 GB/T 7767-1994 炭黑术语 Standard terminology relating to carbonblack
137 GB/T 7983-1987 输送带成槽性试验方法 Conveyor belts--Troughability--Method of test
138 GB/T 7984-1987 普通用途织物芯输送带 Conveyor belts of duck construction for general use
139 GB/T 7985-1987 输送带带芯抗撕裂性试验方法 Conveyor belts--Carcass tear resistance--Method of test
140 GB/T 9571-1988 橡胶、塑料软管静态条件下耐臭氧性能的评定 Rubber and plastics hoses--Assessment of ozone resistance under static conditions
141 GB/T 9572-1988 橡胶塑料软管和软管组合件电阻的测定 Rubber and plastics hoses and hose assemblies--Determination of electrical resistance
142 GB/T 9573-1988 橡胶、塑料软管和软管组合件尺寸测量方法 Rubber and plastics hoses and hose assemblies--Methods of measurement of dimensions
143 GB/T 9574-1988 橡胶、塑料软管和软管组合件试验压力、爆破压力与设计工作压力的比率 Rubber and plastics hoses and hose assemblies--Ratios of proof and burst pressure to design working pressure
144 GB/T 9575-1988 橡胶、塑料软管内径尺寸和长度公差 Rubber and plastics hoses--Bore diameters and tolerances on length
145 GB/T 9577-1988 橡胶、塑料软管和软管组合件标志、包装和运输规则 Rubber and plastics hoses and hose assemblies--Specification for mar king, package and transportation
146 GB/T 9578-1988 标准参比炭黑 Standard reference black
147 GB/T 9580-1988 标准参比炭黑的鉴定方法 Standard practice for carbon black--Evaluation of a standard reference black
148 GB 9745-1995 航空轮胎 Aircraft tyre
149 GB/T 9746-1995 航空轮胎系列 Series of aircraft tyres
150 GB/T 9747-1988 航空轮胎动力模拟试验方法 Dynamometer test methods for aircraft tyres
151 GB/T 9766-1994 轮胎气门嘴试验方法 Test method for tyre valve
152 GB/T 9767-1994 轮胎气门芯试验方法 Test method for tyre valve core
153 GB/T 9768-1988 轮胎使用与保养规程 Regulation of application and maintenance of tyres
154 GB/T 9769-1988 轮辋轮廓检测 Rim contour inspection
155 GB/T 9770-1988 钢丝绳芯输送带 Steel cord conveyor belts
156 GB 9865-1988 硫化橡胶样品和试样的制备 Rubber, vulcanized--Preparation of samples and test pieces
157 GB/T 9865.1-1996 硫化橡胶或热塑性橡胶样品和试样的制备 第一部分: 物理试验 Rubber, vulcanized or thermoplastic--Preparation of samples and test pieces--Part1: Physical tests
158 GB/T 9867-1988 硫化橡胶耐磨性能的测定 (旋转辊筒式磨耗机法) Rubber--Determination of abrasion resistance using a rotating cylinderical drum device
159 GB/T 9868-1988 橡胶获得高于或低于常温试验温度通则 Rubber--General directions for achieving elevated or subnormal temperatures for test purposes
160 GB/T 9870-1988 弹性体动态试验的一般要求 Elastomers--General requirements for dynamic testing
161 GB/T 9871-1988 硫化橡胶老化性能的测定 (拉伸应力松弛试验) Rubber,vulcanized--Determination of ageing characteristics by measurement of stress at a given elongation
162 GB/T 9873-1988 橡胶中铅含量的测定 双硫腙光度法 Rubber--Determination of lead content--Dithizone photometric method
163 GB/T 9874-1988 硫化橡胶中金属含量的测定 火焰
原子吸收光谱法 第三部分: 铅含量的测定 Vulcanized rubber--Determination of metal content--Flame atomic absorption spectrometric method--Part 3: Determination of lead content
164 GB/T 9875-1988 硫化橡胶中聚合物的鉴定 化学方法 Vulcanized rubber--Identification of polymers--Chemical method
165 GB/T 9877.1-1988 旋转轴唇形密封圈结构尺寸系列 第一部分: 内包骨架旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 1: rubber covered rotary shaft lip seals
166 GB/T 9877.2-1988 旋转轴唇形密封圈结构尺寸系列 第二部分: 外露骨架旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 2: Metal cased rotary shaft lip seals
167 GB/T 9877.3-1988 旋转轴唇形密封圈结构尺寸系列 第三部分: 装配式旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 3: assembled rotary shaft lip seals
168 GB/T 9881-1988 橡胶与橡胶制品通用术语 Rubber and rubber products general-purpose terms
169 GB/T 9882-1988 再生橡胶术语及定义 Reclaimed rubber terms and definitions
170 GB/T 9885-1988 食品用及医用橡胶制品术语 Terms of rubber products for foodstuff and medicine
171 GB/T 9887-1988 胶乳制品术语 Rubber latices products terms
172 GB/T 9900-1988 抽出式难燃橡胶导风筒 Extractable ventilation rubber ducting of the fire retardant
173 GB 10213-1995 一次性使用橡胶检查手套 Singie-use rubber examination glove-Specification
174 GB/T 10541-1989 近海停泊排吸油橡胶软管的分类、规格和基本技术要求 Classification, dimension and basic requirements for rubber hose—Oil suction and discharge—Offshore mooring
175 GB 10543-1989 飞机地面加油和泄油用橡胶软管 Rubber hoses for aircraft ground fuelling and defuelling
176 GB/T 10544-1989 钢丝缠绕增强外覆橡胶的液压橡胶软管和软管组合件 Rubber hoses and hose assemblies—Rubber-covered,spiral wire reinforced, hydraulic type—Specification
177 GB 10546-1989 液化石油气 (LPG) 橡胶软管 Liquid petroleum gas rubber hose
178 GB/T 10652-1989 高聚物多孔弹性材料弹性的测定 Polymeric materials, cellular flexible—Determination of resilience
179 GB/T 10653-1989 高聚物多孔弹性材料压缩永久变形的测定 Polymeric materials, cellular flexible—Determination of compression set
180 GB/T 10654-1989 高聚物多孔弹性材料拉伸强度和扯断伸长率的测定 Polymeric materials, cellular flexible—Determination of tensile strength and elongation at break
181 GB/T 10655-1989 高聚物多孔弹性材料空气透气率的测定 Polymeric materials, cellular flexible—Determination of air flow permeability
182 GB/T 10707-1989 橡胶燃烧性能测定 氧指数法 Rubber—Determination of flammability by oxygen index
183 GB/T 10708.1-1989 往复运动橡胶密封圈结构尺寸系列 第一部分: 单向密封橡胶密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 1: Rubber seals of act on single seal
184 GB/T 10708.2-1989 往复运动橡胶密封圈结构尺寸系列 第二部分: 双向密封橡胶密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 2: Rubber seals of act on doubls seal
185 GB/T 10708.3-1989 往复运动橡胶密封圈结构尺寸系列 第三部分: 橡胶防尘密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 3: rubber seals for wipers
186 GB/T 10714-1989 V 带难燃性规范和试验方法 V-belts—Specification of the fire-resistivity and the test method
187 GB/T 10715-1989 抗静电环形V带导电性规定值和试验方法 Antistatic endless V-belts—Electrical conductivity —Characteristic and method of test
188 GB/T 10716-1989 同步带拉伸性能试验方法 Synchronous belt—Test method for tensile properties
189 GB/T 10717-1989 同步带齿剪切强度试验方法 Synchronous belt—Test method for tooth shearing strength
190 GB/T 10718-1989 同步带包布剥离强度试验方法 Synchronous belt—Test method for fabric stripping strength
191 GB/T 10719-1989 同步带绳抽出强度试验方法 Synchronous belt—Test method for cord pull-out strength
192 GB/T 10722-1989 炭黑比表面积的测定 氮吸附方法 Carbon black—Determination of specific surface area —Nitrogen adsorption method
193 GB/T 10723-1989 用ASTM标准参比炭黑改善炭黑试验再现性的标准方法 Standard method for carbon black—Improving test reproducibility using ASTM reference blacks
194 GB/T 10821-1993 农业机械用V带尺寸 V-belts for agricultural machinery-Dimensions
195 GB/T 10822-1989 一般用途难燃输送带 Frame retardant conveyor belts for general use
196 GB/T 10823-1996 充气轮胎轮辋实心轮胎系列 Series of solid tyres for pneumatic tyres rims
197 GB/T 10824-1996 充气轮胎轮辋实心轮胎 Solid tyres for pneumatic tyres rims
198 GB/T 11063-1989 聚酰胺片基平带 Polyamide plate based flat belt
199 GB/T 11191-1989 航空轮胎爆破压力试验方法 Burst pressure test method for aircraft tyre
200 GB/T 11192-1989 航空轮胎静负荷性能试验方法 Test method of static loaded perfor mance for aircraft tyre
摘自:
http://www.laliceshiyi.com/Ji_Shu_Wen_Zhang/index.html
