AQF-2100H Advanced,developed to the second generation.Powerful,fast solution for sulfur and halogen (Chlorine,Fluorine,Bromine,Iodine)analysis. 先进的第二代自动快速燃烧裂解吸收离子色谱系统,快速、可靠、准确的分析样品中的硫和卤素(F,Cl,Br,I) Features产品特点 SKILL FREE OPERATION无障碍操作 Thanks to the new combustion program and double tube system,sample can now be combusted surely and safely without special skill and training.Sample combustion can be completed in as short as 5 min. 由于新的燃烧程序和双裂解管系统,样品燃烧的更加彻底和安全,完全燃烧的时间短至5分钟。 New developed unique combustion method can be applied for various samples,e.g. Heavy matrix,different pyrolysis temperature of elements,and even to completely unknown samples.This program can also enable larger amount of sample up to 150mg. 新研发的独一无二的燃烧方法可以应用于各种的样品。比如:重基质样品,不同裂解温度的元素,及未知样品的完全燃烧。同时这套程序可以燃烧重达150mg的样品。 PYROHYDROLYTIC COMBUSTION SYSTEM 高温裂解燃烧系统 Controlled pyrohydrolytic combustion enables highly accurate analysis of Fluorine,high concentration Chlorine,and Bromine. 控制高温裂解燃烧使精确分析F,Cl,Br成为可能 HIGH SENSITIVE ANALYSIS高灵敏分析 Thanks to dedicated gas controller unit,extremely low gas blank is realized. 精确的气体控制单元,使得气体空白更低。 By utilizing high purity quartz tube,trace analysis can be applicable. 高纯度的石英管,更适用于痕量分析。 ABSORBENT CORRECTION 吸收液修正 Constant volume function enables high accurate analysis and easier operation.Since there is no longer need to use internal standards,samples with complex matrix can be measured. 定容功能的使用使得分析更加精确,操作更加简单。不再使用内标,复杂基质的样品也能检测。 ACCESSIBILITY 辅助功能 Customer can easily access the combustion tube for daily maintenance.Cleaning and set up of tubes are more convenient.用户可以更加方便的查看裂解管,进行日常的查看,维护和拆卸清理。 NEW SOFTWARE,FULL AUTOMATIC OPERATION & SHUT DOWN 全新的软件,全自动的操作和关机 Fully automatic operation is available from calibration.boat prebake to sample analysis. 全自动操作同样适用于校准,样品分析时样品舟的预烧。 Also auto shut down is configurable by simple 3 steps,[heater off],[GA-210 wash],and [gas valve off]. 同样自动关机也分为简单的三步,[加热炉关闭],[GA-210自动清洗],[关闭气阀]。 |
Sample | In the combustion tube | In the absorbent | ||||
Sulfur | [img=,35,]file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml17168/wps1.png[/img] | SOx | [img=,35,]file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml17168/wps2.png[/img] | SO42- | [img=,19,]file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml17168/wps3.png[/img] | Ion Chromatogaph |
Halogen | [img=,35,]file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml17168/wps4.png[/img] | HX,X2 | [img=,35,]file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml17168/wps5.png[/img] | X- |
METHOD NUMBER | TITLE | ELEMENTS |
ASTM D5987 | Standard Test Method for Total Fluorine in Coal and Coke by Pyrohydrolytic Extraction and Ion Selective Electrode or Ion Chromatograph Methods | F |
ASTM D7359 | Standard Test Method for Total Fluorine,Chlorine and Sulfur in Aromatic Hydrocarbons and Their Mixture by Oxidative Pyrohydrolytic Combustion followed by Ion Chromatography Detection(Combustion Ion Chromatography-CIC | F,Cl,S |
JIS K7392 | Total bromine in waste plastics | Br |
JIS R9301(ISO 2828) | Alumina powder:Determination of Fluorine content | F |
JIS R1616 | Methods for chemical analysis of fine silicon carbide powders for fine ceramics | F,Cl |
JIS R1603 | Methods for chemical analysis of fine nitride powders for fine ceramics | F,Cl |
JIS Z7302 | Densified refuse derived fuel-test method for total chlorine/sulfur contents | Cl,S |
JEITA ET-7304A | Definition of Halogen-free Soldering Materials | F,Cl,Br,I |
KS M0180 | Standard Test Method for halogen(F,Cl,Br)and Sulfur content by oxidative pyrohydrolytic combustion followed by ion chromatography detection for electronic equipment | F,Cl,Br,S |
