今天打开高效
液相工作站后出现一个对话框,内容如下:
A hardware connection has been established. The modules configured do not
match the actual modules connected.Please check that all modules in the
Class VP configuration are powered on and detected on the SCL Configuration
screen.DO NOT ACQUIRE DATA if this message box appears.close
instrument and then re-open before acquiring any data.
有高手帮解答一下 谢谢
