原文由 luoxiandong(luoxiandong) 发表:
Regulation: SOR/2010-298
Product scope should be:
1)Children's Toys (for children <14 years learning or play)
2)Child care article.(“child care article” means a product that is intended to facilitate the relaxation, sleep, hygiene, feeding, sucking or teething of a child under four years of age.)
Test part:
Accessible material only
Coating/plating/ fabric will not consider as barrier.
Test materials:
Vinyl (know as PVC)
Limit:
DEHP, DBP and BBP
The vinyl in a toy or child care article must contain not more than 1 000 mg/kg of di(2-ethylhexyl) phthalate (DEHP), dibutyl phthalate (DBP) or benzyl butyl phthalate (BBP) when tested in accordance with a method that conforms to good laboratory practices.
DINP, DIDP and DNOP
The vinyl in any part of a toy or child care article that can, in a reasonably foreseeable manner, be placed in the mouth of a child under four years of age must contain not more than 1 000 mg/kg of diisononyl phthalate (DINP), diisodecyl phthalate (DIDP) or di-n-octyl phthalate (DNOP) when tested in accordance with a method that conforms to good laboratory practices.
For more informations, you could use below links:
http://laws-lois.justice.gc.ca/eng/regulations/SOR-2010-298/index.html
看了SOR/2010-298,有点疑惑,第二点“Test part”在法令的那个部分里有提及?我看了两遍,没有找到有表述“可接触”的字眼。谢谢。
