F 可燃性试验项目
FLAMMABILITY TESTS
普通织物的燃烧性能 flammability of general clothing textiles
布料的燃烧速率(45。角) burning rate of cloth (45。angle)
瑞典成衣燃烧性能 Sweden fire properties of apparel textile
G 织物性能试验项目
FABRIC FERFORMANCE TESTS
耐磨性 abrasion resistance
抗起毛起球性 pilling resistance
拒水性 water repellency
抗水性 water resistance
折痕回复力 wrinkle recovery
布料硬挺度 fabric stiffness
弹性及回复力 stretch & recovery
H 羽绒试验项目
FEATHER & DOWN THERMAL TESTS
羽绒成分分析 composition analysis
膨松度 filling power
杂色毛和绒的比例 black tip
填充料的净重量 new weight (conditioned) of filling material
含水率 moisture content
溶剂可溶物的测定 determination of solvent solube
酸度 acidity
好氧指数 oxygen number
清洁度 turbidity test
羽绒布防漏性 penetration resistance of cloth to feather & down
I 成衣附件试验项目
GARMENT ACCESSORY TESTS (LACE, ZIPPER, BUTTON, BUCKLE, ETC.)
洗涤后外观 appearanc after laundering
贮存后外观 appearance after storage
耐烫性能 resistance to ironing
拉链强力 zipper strength
拉链的往复性 reciprocating test
拉链耐用性 durability of zipper
拉链的使用性能 operability of zipper
魔术贴剪力 shear strength of hooks & loops fastener (velcro tape)
魔术贴撕离力 peeling strength of hooks & loops fastener (velcro tape)
魔术贴分合 consecutive adhere/ separation exercising on hooks & loops fastener (velcro tape)
金属抛光物的锈蚀/变色试验 corrosion / tarnish test on metallic finishes
按钮分开强力 unsnapping og snap fasteners
金属钮扣、铆钮的紧固试验 security of metallics buttons, rivets, ets.
按钮的紧固试验 security of snap button
钮扣强力 strength of buttons
耐洗液腐蚀性 resistance to wash liquor
耐干洗溶剂腐蚀性 resistance to drycleaning solvents
钮扣撞击测试 button impact test
钮扣拉力试验 button tension test
钮扣钮力试验 button torque test
按钮附着力 snap attachment strength
装饰物附着力 trim attachment strength
J 其他纺织品测试项目
OTHER TEXTILE TESTS
适当试验后推荐护理标签 care instruction/label recommendation after appropriate testing (testing charges excluded)
成衣尺寸测量 garment size measurement
硫化染料染色的纺织品的加速老化 accelerated ageing of sulphur-dyed textiles
色差判定 colour difference assessment
K 纤维和纱的试验项目
FIBRE & TESTS
短纤维长度 fibre staple length
线形密度 linear density
纤维直径 fibre diameter
单根纤维强力 single fibre strength
纤维韧性 tenacity of fibre
纱支 yarn count
纱线纤度(原样) denier count as received
连续或非连续纤维的识别 identification of continuous/ discontinuous fibres
每卷经纱长 length of thread per roll
纱线净重 net weight of thread
单纱强力 single thread strength
绞纱强力 lea strength
线圈强力 loop strength
纱线韧性 tenacity of yarn
纱捻度 twist per unit
L 填充棉试验
BATTING TESTS
重量 weight
厚度 thickness
纤维含量 fibre content
树脂含量 resin content
压缩与回复试验 compresssion and resilience test
样品分析前准备 sample dissection for analysis preparation
皂洗尺寸稳定性 dimensional stability to washing
机洗/水洗后的外观 appearance after laundering / hand wash
M 地毯试验项目
CARPET TESTS
摩擦色牢度 colour fastness to rubbing
光照色牢度 colour fastness to light
水渍色牢度 colour fastness to water
毛束联结牢度 tuft withdrawal force (tuft bind)
毛束经密度 pitches per unit length
毛束纬密度 rows per unit length
底布密度 threads per unit length of backing
单位面积重量 weight per unit area
表面毛绒密度(只做单层毛毯) surface pile density (single level pile carpet only)
起绒纱股数 ply of pile yarn
割绒种类 type of cut pile
毛绒或毛圈长度 pile or loop length
毛绒或底部的纤维成分 fibre composition of pile & back
