本人现在用英国药典中规定的酸碱滴定的方法测定氨甲环酸注射液含量,结果总是偏低,且数据重现性不好。
ASSAY
To a volume containing 0.1 g of Tranexamic Acid add 50 ml of water and adjust the solution
to pH 7.0 with 0.1M sodium hydroxide or 0.1M hydrochloric acid . Add 25 ml of formaldehyde
solution , previously adjusted to pH 7.0, and 20 ml of 0.1M sodium hydroxide VS and titrate
with 0.1M hydrochloric acid VS determining the end point potentiometrically. Repeat the
operation without the injection. The difference between the titrations represents the amount of
sodium hydroxide required. Each ml of 0.1M sodium hydroxide VS is equivalent to 15.72 mg
of C8H15NO2.
取本品适量(含氨甲环酸0.1g),加入50ml水,用浓度为0.1mol/L的氢氧化钠溶液或0.1mol/L的盐酸溶液调节pH至7.0.加入25ml甲醛溶液(pH调节至7.0),再加入20ml浓度为0.1mol/L的氢氧化钠溶液,用0.1mol/L的盐酸滴定液滴定至终点。空白溶液(不加氨甲环酸样品)相同操作。滴定差值即为所需氢氧化钠的量。每毫升0.1mol/l氢氧化钠滴定
液相当于15.72mgC8H15NO2.
1.请问上述翻译是否无误?
2.方法中没有明确指出用哪种指示剂,我们选用的是酚酞,不知道是否会给结果带来影响。英国药典中的指示剂选用应该怎么查呢?
3.加甲醛后未再调PH至7
4.还有哪些因素会让结果不稳定,及含量值偏低呢?还请各位大侠指点,小女子万分感激啊啊啊
