【作者】 翁水旺; 连劲龙;
【Author】 Weng Shuiwang (Fujian Provincial Institute for Drug Control,Fuzhou 350001)Lian Jinlong (Fujian University of Medical Sciences,Fuzhou 350004)
【机构】 福建省药品检验所; 福建医科大学 福州 350001; 福州 350004;
【摘要】 目的:采用高效
液相色谱法测定醋柳黄酮片中异鼠李素和槲皮素的含量。方法:采用Diamonsil C18(250mm×4.6mm,5μm)色谱柱,流动相为甲醇-0.02mol/L磷酸溶液(54:46),柱温40℃,检测波长368nm。结果:异鼠李素、槲皮素的线性范围分别为:6.5~32μg/ml(r=0.9996)、2.5~12.4 μg/ml(r=0.9991),平均回收率为99.4%、99.8%。日内精密度RSD分别为1.22%、1.32%(n=6);日间精密度RSD为1.07%、1.35%(n=5)。结论:本方法简便、准确,适用于该药的质量控制。 更多还原
【Abstract】 Objective: A method was established for the determination of isorhamnetine and quercetin in flavone hippophaes tablets by HPLC.Methods:The HPLC system consisted of Diamonsil C18 column (250 mm×4.6 mm, 5μm), mobile phase of methanol-0.02mol/L phosphoric acid (54:46) .column temperature at 40℃,with detection at 368 nm. Results:The linear range of isorhamnetine and quercetin were 6.5-32μg/ml (r = 0.9996) and 2.5-12.4 μg/ml (r= 0.9991).The average recoveries were 99.4% and 99.8%,respectively.The wit... 更多还原
【关键词】 醋柳黄酮片; 异鼠李素; 槲皮素; 高效
液相色谱法;
【Key words】 Flavone hippophaes tablets; Isorhamnetine; Quercetin; HPLC;
