【作者】 李健英; 王连芝;
【Author】 LI Jian-ying,WANG Lian-zhi(Research Institute of Traditional Chinese Medicine,Heilongjiang University of Chinese Medicine,Harbin 150040,China)
【机构】 黑龙江中医药大学中医药研究院;
【摘要】 目的:建立中药壮骨灵胶囊中淫羊藿苷含量的测定方法。方法:采用高效
液相色谱法。色谱柱:Diamonsil C18柱(250mm×4.6mm,5μm);流动相:乙腈-水(30∶70);检测波长:270nm;柱温:40℃;流速:1.0mL/min。结果与结论:淫羊藿苷在0.1~0.18μg范围内线性关系良好,相关系数r=0.999 9,淫羊藿苷含量平均值为0.287 8mg/g,该法准确、可靠、重复性好,可用于壮骨灵胶囊中淫羊藿苷含量的测定。 更多还原
【Abstract】 Objective: To establish a method of HPLC for determination of icariin in Zhuangguling capsules.Methods: The HPLC column was Diamonsil C18(5μm,250×4.6mm).The mobile phase consisted of acetonitrile-water(30∶ 70) at the flow rate of 1.0ml/min.The column temperature was 40℃.The detection wavelength was set as 270nm.Results: The linear range of icariin was 0.1ug~0.18ug(r=0.999 9),and the average recovery was 102.4%(RSD=1.35%).Conclusion:The method is accurate,reliable and reproducible,and it can be u... 更多还原
【关键词】 高效
液相色谱法; 壮骨灵胶囊; 淫羊藿苷;
【Key words】 HPLC; Zhuangguling capsule; Icariin;
【基金】 黑龙江省教育厅科技攻关项目(11541135)
