主题:【分享】文献检索任务一八三(183.1-183.10)
浏览0 回复9 电梯直达
qq250083771
183.1 HPLC法测定盐酸丁丙诺啡注射液中5-羟甲基糠醛
【作者】 杨杨; 刘永成; 姜连阁; 白政忠;
【Author】 Yang Yang ,et al Heilongjiang Institute for Drug Control(Harbin 150001)
【机构】 黑龙江省药品检验所;
【摘要】 目的:建立高效液相色谱法检查盐酸丁丙诺啡注射液中5-羟甲基糠醛。方法:采用Diamonsil C18(4.6mm×250mm,5μ),甲醇-乙腈-2%醋酸铵溶液-冰醋酸(60:10:40:5)为流动相,流速为1.0ml/min,检测波长为284nm,柱温为30℃。结果:5-羟甲基糠醛色谱峰与主峰能够达到有效分离,检测限为0.752ng/ml,定量限为4.512ng/ml,平均回收率为99.9%(RSD=1.2%)。结论:本法简便,灵敏、准确、专属性强,可用于盐酸丁丙诺啡注射液中5-羟甲基糠醛的检查。 更多还原
【Abstract】 Objective: To establish an HPLC method for determination of 5-Hydroxymethyl furfuraldehyde in Buprenorphine Hydrochloride Injection.Methods: The Diamonsil C18(4.6mm×250mm,5μ) column was used,the mobile phase consisted of methanol-acetonitrile-2%Ammonium acetate-acetic acid(60:10:40:5),the flow rate was 1.0ml/min,the detection wavelength was 284nm,Temperature: 30℃. Results: The peak of 5-Hydroxymethyl furfuraldehyde in Buprenorphine Hydrochloride for Injection can be separated effectively, the li... 更多还原
【关键词】 5-羟甲基糠醛; 盐酸丁丙诺啡注射液; 高效液相色谱法;
【Key words】 5-Hydroxymethyl furfuraldehyde; Buprenorphine Hydrochloride Injection; HPLC;
qq250083771
183.2 HPLC法测定丹参冲剂中丹酚酸B的含量
【作者】 孙红丽;
【Author】 Sun HongLi (Heilongjiang Province flights century medical technology Green Development Co., Ltd,(Harbin 150000)
【机构】 黑龙江省绿航世纪医药科技开发有限公司;
【摘要】 目的:采用HPLC法测定丹参冲剂中丹酚酸B的含量。方法:采用DiamonsilC18柱(5μ,200×4.6mm);以甲醇-乙腈-甲酸-水(30:10:1:59)为流动相;流速:1.0ml·min-1;检测波长:286nm。结果:丹酚酸B在12.08~120.80μg·ml-1浓度范围内线性关系良好,平均加样回收率为99.42%(n=9),RSD=0.53%。结论:建立的方法可准确测定丹参冲剂中丹酚酸B的含量。 更多还原
【Abstract】 Objective: To determine the content of salvianolic acid B in salvia miltiorrhiza preparation by HPLC.Methods:Using the Diamonsil C18 column(5μ,200×4.6mm),its mobile phase was methane alcohol-acetonitrile-acid-water(30:10:1:59).The flow velocity was 1.0ml·min-1 and the detective wavelength of salvianolic acid B was 286nm.Results:It was showed that the salvianolic acid B had a good linearity in the range of 12.08~120.80μg·ml-1.The average recovery was 99.42%(n=9),and RSD=0.53%.Conclusion:The estab... 更多还原
【关键词】 丹参冲剂; 丹酚酸B; HPLC法; 含量测定;
【Key words】 salvia miltiorrhiza preparation; Salvianolic acid B; HPLC; content determination;
【文内图片】
qq250083771
183.3 复方甘草酸单铵注射液有关物质方法学研究
【作者】 姜海波; 胡玉庆;
【Author】 Jiang Haibo Harbin Gloria Pharmaceutical Co.,Ltd(150025)
【机构】 哈尔滨誉衡药业有限公司; 黑龙江省智诚医药科技有限公司 黑龙江哈尔滨150025; 黑龙江哈尔滨150060;
【摘要】 目的:建立复方甘草酸单铵注射液有关物质检查方法。方法:采用高效液相色谱法,以Diamonsil-C18 (250mm×4.6mm×5μm)为色谱柱;流动相:甲醇-0.2mol/L乙酸铵溶液-冰乙酸(70:30:1);检测波长:250nm。结果:有效的分离了复方甘草酸单铵注射液中的有关物质,各杂质峰面积总和不大于对照液主峰面积的20.0%,最大杂质不大于对照液主峰面积的10.0%;结论:此方法简便,快速,可用于复方甘草酸单铵注射液的质量控制。 更多还原
【Abstract】 Objective:To determine the related compounds in Compound Ammonium Glycyrrhetate Injection by HPLC.Methods:The determination was performed on Diamonsil-C18(250mm×4.6mm×5μm)column,and the mobile phase was composed of methanol-solution of 0.2mol/L Ammonium acetate-Acetic acid glacial(70:30:1)and detection wavelength of 250nm.Results:The related substances in Compound Ammnonium Glycyrrhetate Injection were separated effectively.The total peak area of all foreign materials was no more than 20.0% of t... 更多还原
【关键词】 复方甘草酸单铵注射液; 有关物质; 高效液相色谱法;
【Key words】 Compound Ammonium Glycyrrhetate Injection; related compounds; HPLC;
【文内图片】
qq250083771
183.4 HPLC法测定参芪合剂中人参皂苷Rg1的含量
作者:  赵秀香    刘书坤
作者单位:  山东省胸科医院药剂科,250013
期 刊:  黑龙江医药
Journal:  HEILONGJIANG MEDICINE JOURNAL
年,卷(期):  2007, 20(4)
分类号:  R927.2
关键词:  高效液相色谱法    参芪合剂    人参皂苷Rg1
摘要: 目的:用高效液相色谱法测定参芪合剂中人参皂苷Rg1的含量.方法:选用Diamonsil C18分析柱(5 μm,250 mm×4.6 mm),乙腈-水(23∶77)为流动相,检测波长为203 nm,流速1.0 mL/min.结果:线性范围0.8~4.0 μg(r=0.9999)平均回收率为98.85%,RSD为0.97%.结论:本法简便、灵敏、准确.
qq250083771
183.5 HPLC法测定消喘膏中延胡索乙素的含量
作者:  万海江[1]    王苏艳[1]    姜玲玲[2]
Author:  Wan Haijiang[1]    Wang Suyang[1]    Jiang Lingling[2]
作者单位:  黑龙江天龙药业有限公司,哈尔滨,150060
黑龙江济仁药业有限公司
期 刊:  黑龙江医药
年,卷(期):  2006, 19(3)
分类号:  R2
关键词:  消喘膏    延胡索乙素    高效液相色谱法
摘要: 目的:测定消喘膏中延胡索乙素的含量.方法:色谱柱为Dikma Diamonsil C18(200mm×4.6mm,5μm),流动相为甲醇-0.1%磷酸溶液(三乙胺调pH值至6.0)(55:45),流速为1.0ml·min-1,检测波长为280nm.结果:延胡索乙素进样量在0.051μg~1.020μg范围内与峰面积呈良好的线性关系(r=0.9999),平均回收率为99.35%(n=9),RSD为0.75%.结论:本方法简便快速,分离度好,结果准确可靠.
qq250083771
183.6 HPLC法测定感冒清热颗粒中葛根素的含量
【作者】 苏文政; 唐汉华;
【Author】 SU Wen-zheng,TANG Han-hua Hunan Province Xiangzhong Drug Preparation Company Limited,Shaoyang,Hunan,422000
【机构】 湖南省湘中制药有限公司;
【摘要】 目的:建立感冒清热颗粒中葛根素的含量测定方法。方法:采用HPLC法,C18柱,甲醇-水(22:78)为流动相,检测波长为250nm。结果:葛根素在0.1384-1.384μg范围内线性关系良好,平均回收率为99.84%,RSD%=1.65%(n=6)。结论:该方法简便,准确,灵敏度高,重现性好,可用于感冒清热颗粒的质量控制。 更多还原
【Abstract】 Objective:To establish the determination method of kakkonein in Ganmaoqingre granule.Methods:HPLC method was used,the chromatographic condition consisted of C18 column with methanol-water(22:78) as mobile phase at the detection wavelength of 250 nm.Results:Kakkonein showed a linear relationship at the range of 0.1384-1.384 μg,the average recovery was 99.84%,RSD%=1.65%(n=6).Conclusion:The method is simple,accurate,high sensitivity and good reproducibility,can be used as quality control for Ganmao... 更多还原
【关键词】 感冒清热颗粒; 葛根素; HPLC;
【Key words】 Ganmaoqingre granule; Kakkonein; HPLC;
qq250083771
183.7 高效液相色谱法测定壮肾安神片中淫羊藿苷的含量
【作者】 杨文波; 段玉梅;
【Author】 Yang Wenbo Harbin No.2 biochemistry pharmaceutical factory(Harbin 150046)
【机构】 哈尔滨生物化学制药二厂; 哈尔滨市医药集团新药特药商店 (哈尔滨150046);
【摘要】 目的:采用高效液相色谱法测定壮肾安神片中淫羊藿苷的含量。方法:高效液相色谱柱:Diamonsil(钻石)HPLC 色谱柱(4.6×150mm)流动相:乙腈—水(30∶70),检测波长270nm,结果:回收率为96.82%,RSD=1.38%。结论:方法简便,快速准确,可作为该制剂的质量控制方法。 更多还原
【Abstract】 Objective:To deteminate content of icaritin in zhuangshenanshen Tablets by HPLC.Method:Efficiently liquid HPLC pillar:Diamonsil (diamond) HPLC the pillar (4.6× 150mm) flow the—water (30:70),examination wave—length 270 nms,result:Recovery rate is 96.82%,RSD=1.38%.Conclusion:Method is simpk and the fleetness is accurate,and can be used as the quantity of that product the control method. 更多还原
【关键词】 壮肾安神片; 淫羊藿苷; 高效液相色谱法;
【Key words】 Zhuangshenanshen Tablets; icaritin; HPLC;
【文内图片】
qq250083771
183.8 高效液相色谱法测定盐酸环丙沙星片含量的稳定性
【作者】 王基平; 闫丽;
【Author】 Wang Jiping Harbin Sanjing Pharmaceutical Limited company(150010)
【机构】 哈药集团三精制药有限公司科研所; 哈药集团三精制药有限公司科研所 (哈尔滨150010); (哈尔滨150010);
【摘要】 目的:针对高效液相色谱法测定盐酸环丙沙星片含量结果偏差大进行进一步讨论,用于生产及质量控制。方法:以 DiamonsiL—C18(250×4.6mm,5um)为色谱柱;用0.05mol/L 枸橼酸溶液-乙晴(82:18)用三乙胺调节 pH 值至3.5为流动相,检测波长277nm,流速为1.0ml/min,以外标法按峰面积计算。结论:在含量测定过程中,发现过滤用的定性滤纸对环丙沙星有吸附,以致使含量测定结果出现假象,经多次试验,直接采用微孔滤膜过滤,可真实反映含量测定结果。 更多还原
【Abstract】 Objective:About determination Ciprofloxacin Hydrochloride tablet content result deviation of HPLC method go a step further discussion,for produce and quatity control.Method: Chromatographic column is DiamonsiL-C18 (250×4.6mm,5um),Mobile phase is 0.05mol/L Citric Acid.Solution-Acetonitrile(82:18).Use Triethy camine adjust PH to 3.5,Detection wave length:277mm,on this condition.Current Velocity is 1.0ml/min.According to peak area to calcu- late with external standard method.Result:In th... 更多还原
【关键词】 高效液相色谱法; 盐酸环丙沙星片; 定性滤纸; 微孔滤膜;
【Key words】 HPLC Method; Ciprofloxacin Hydrochloride; Qualitative Filter Paper; Millipore Membrance;
【文内图片】
qq250083771
183.9 HPLC法测定麝香接骨胶囊中血竭素的含量
【作者】 丛培臣; 梁伟; 宋丽岩; 张欣;
【Author】 Cong Peichen Shiytang Pharmaceutical Factory of Harbin Pharmaceutical Group (Harbin 150088)
【机构】 哈药集团世一堂制药厂; 哈药集团世一堂制药厂 哈尔滨150088; 哈尔滨150088;
【摘要】 目的:用 HPLC 法测定麝香接骨胶囊中血竭素的含量。方法:HPLC 法,色谱柱:Diamonsil(钻石)HPLC 色谱柱(4.6×150mm),流动相:乙腈-3%磷酸溶液(50:50),检测波长440nm。结果:回收率为99.52%,RSD=0.89%。结论:方法简便、快速准确,可作为该制剂的质量控制方法。 更多还原
【Abstract】 Objective:To determine the content of dracorhodin in SHEXIANG JIEGU CAPSULE by HPLC.Methods:Separation was achieved on a Diamonsil column(4.6×150mm). The mobile phase was aeetonitrile-3% phosphoric acid(50:50),the wavelength of the UV detecor 440nm.Results:The average recovery was 99.52%.RSD was 0.89%.Conclusion:The method is simple and accurate.It can be used to control the quality of SHEXIANG JIEGU CAPSULE. 更多还原
【关键词】 麝香接骨胶囊; 血竭素高氯酸盐; 高效液相色谱法;
【Key words】 SHEXIANG JIEGU CAPSULE; dracorhodin perchlorate; HPLC;
qq250083771
183.10 顶空毛细管气相色谱法检测加替沙星中有机溶剂残留量
【作者】 蔡林; 晏菊姣; 李恒;
【Author】 CAI Lin1,YAN Ju-jiao2,LI Heng2(1.181th Hospital of Chinese People’s Libration Army,Guilin 541002,China;2.Wuhan Institute for Drug Control,Wuhan 430012,China)
【机构】 中国人民解放军第181医院; 武汉市药品检验所;
【摘要】 目的:建立加替沙星原料药中乙醇、乙腈、二氯甲烷、乙酸乙酯、甲苯5种有机溶剂残留量的测定方法。方法:采用顶空毛细管气相色谱法,程序升温,色谱柱为DM-624毛细管色谱柱,载气为高纯氮,FID检测器,90%N,N-二甲基甲酰胺水溶液为溶解介质,检测了加替沙星原料药中的乙醇、乙腈、二氯甲烷、乙酸乙酯、甲苯的残留量。结果:5种溶剂残留均达到良好分离,在所考察的浓度范围内具有良好线性,r=0.999 7~0.999 9,乙醇、乙腈、二氯甲烷、乙酸乙酯、甲苯的检测限均小于3μg/g,精密度RSD均小于5%,平均回收率为94.8%~98.6%。结论:本试验建立的方法简单、快捷且灵敏度高,可以用于加替沙星中乙醇、乙腈、二氯甲烷、乙酸乙酯、甲苯5种有机溶剂残留量的测定。 更多还原
【Abstract】 Objective:To establish a method for determination of five residual solvents in gatifloxacin.Methods: The residual organic solvents which are ethanol,acetonitrile,dichloromethane,ethyl acetate,toluene were quantitatively determined by headspace gc on DM-624 column,90%DMF as solvent media,with FID detector,high purity nitrogen as the carrier gas.Results: Five residual solvents were completely separated.There was a good linearity(r=0.999 7~0.999 9).The detection limit of ethanol,acetonitrile,Dichlo... 更多还原
【关键词】 原花青素; PC12细胞; 细胞凋亡;
【Key words】 gatifloxacin; residual solvents; headspace capillary gas chromatography;
