主题:【求助】水稻中福美双的检测
浏览0 回复12 电梯直达
jianglizz
请教高手,用液相做福美双的检测,我是用乙腈提取,过4g弗罗里硅土柱子,结果都没回收,有人做过吗!柱子应该没有问题,大家帮忙分析一下吧!!万分感谢
该帖子作者被版主 雾非雾2积分, 2经验,加分理由:发贴讨论
雾非雾
福美双算是比较难检测的农药,没有做过,以下贴子的几个附件不知道有没有参考意义。
福美双的检测 http://bbs.instrument.com.cn/shtml/20100720/2673121/
MMYG
MMYG
MMYG
雾非雾
EPA方法:Environmental Chemistry Methods: Thiram
附件:
2013/2/1 14:09:58 Last edit by mcds
雾非雾
雾非雾
雾非雾
Quantification of Thiram in Honeybees: Development of a Chemiluminescent ELISA
2013/2/1 16:34:44 Last edit by mcds
雾非雾
Degradation of thiram in water, soil and plants: a study by highperformance liquid chromatography
附件:
雾非雾
原文由 MMYG(jl070869) 发表:
福美双
2763推荐的方法是:LC-MS-MS
用的是石墨化碳净化
A solid-phase extraction procedure for the clean-up of thiram from aqueous solutions containing high concentrations of humic substances.
Filipe OM, Vidal MM, Duarte AC, Santos EB.
Source
Departamento de Ciências Exactas e do Ambiente, Escola Superior Agrária de Coimbra, Bencanta 3040-316 Coimbra, Portugal; CERNAS, Centro de Estudos de Recursos Naturais, Ambiente e Sociedade, Escola Superior Agrária de Coimbra, Bencanta 3040-316 Coimbra, Portugal.
Abstract
A simple solid-phase extraction (SPE) procedure with an octadecyl bonded phase silica (C(18)) was developed for clean-up of the fungicide thiram from aqueous solutions containing high concentrations of humic substances, for future studies of thiram adsorption onto solid humic substances or soils. Suspensions of humic acids and soil, in aqueous 0.01M CaCl(2) solution, were prepared and used as samples. These extracts were spiked with thiram and immediately applied to a C(18)-SPE cartridge. Thiram was eluted with chloroform and its concentration measured by spectrophotometry at 283nm. Non-spiked aqueous extracts (blanks) and a control sample of thiram in 0.01M CaCl(2) aqueous solution were also prepared and submitted to the same SPE procedure. The results show that humic substances are extensively retained by the C(18) cartridge but are not eluted with CHCl(3). Recoveries of 100-104% were obtained for thiram in the presence of humic substances. The SPE procedure described in this work is an efficient clean-up step to remove the interference of humic substances absorbance and to be coupled to any spectrophotometric or HPLC-UV method, usually used for thiram analysis in food extracts.
