原著:George M. Whitesides (美国)
译者:张希,林志宏
What is a scientific paper? A paper is an organized description of hypotheses, data and conclusions, intended to instruct the reader. Papers are a central part of research. If your research does not generate papers, it might just as well not have been done. “Interesting and unpublished” is equivalent to “non-existent.”
什么是科技论文?科技论文是集假说、数据和结论为一体的概括性描述,以此向读者论述。论文是研究工作的中心部分。如果你的研究没有写成论文,也就等同于没有做研究。有意义但没有发表,等同于不存在。
Realize that your objective in research is to formulate and test hypotheses, to draw conclusions from these tests, and to teach these conclusions to others. Your objective is not to “collect data.”
要意识到研究的目的是为了形成并证实假说,从一些测试中得出结论,并把结论传授给别人。你的研究目的不是简单的收集数据。
A paper is not just an archival device for storing a completed research program, it is also a structure for planning your research in progress. If you clearly understand the purpose and form of a paper, it can be immensely useful to you in organizing and conducting your research. A good outline for the paper is also a good plan for the research program. You should write and rewrite these plans/outlines throughout the course of the research. At the beginning, you will have mostly plan; at the end, mostly outline. The continuous effort to understand, analyze, summarize, and reformulate hypotheses on paper will be immensely more efficient for you than a process in which you collect data and only start to organize them when their collection is“complete.”
一篇论文并不仅仅是收集已经得到的研究结果,它也有助于形成进一步的研究工作的框架。如果明确了论文的目的,这对于计划开展你的研究工作有很大益处。好的文章提要也是研究工作的好计划,在研究的过程中,应该反复修改这些计划或提要。研究工作开始时,应有完善的计划;工作结束时,应充分的总结。最有效率的做法是及时的理解, 分析, 总结, 形成假说; 而不是等到完成时才开始收集和整理数据。
The reason for outlines. I emphasize the central place of an outline in writing papers, preparing seminars, and planning research. I especially believe that for you, and for me, it is most efficient to write papers from outlines. An outline is a written plan of the organization of a paper, including the data on which it rests. You should, in fact, think of an outline as a carefully organized and presented set of data, with attendant objectives, hypotheses and conclusions, rather than an outline of text.
为什么要写提纲?我在这里要强调提纲在论文写作,准备报告以及研究计划中的重要作用。我尤其相信按照提纲进行写作对我们大家都是最有效的方法。提纲是一篇论文的行文计划,应该包括论文所依靠的数据。事实上,提纲不仅仅是列出各段的内容, 而是按照目的, 假说, 结论来精心组织数据。
An outline itself contains little text. If you and I can agree on the details of the outline (that is, on the data and organization), the supporting text can be assembled fairly easily. If we do not agree on the outline, any text is useless. Much of the time in writing a paper goes into the text; most of the thought goes into the organization of the data and into the analysis. It can be relatively efficient to go through several (even many) cycles of an outline before beginning to write text; writing many versions of the full text of a paper is slow.
提纲本身应该文字简练。如果大家都同意提纲中的细节部分,那么正文组织起来就更容易。在我们就提纲达成一致以前,写正文是没有意义的。 写文章时,大部份时间花在写正文上;而大部份思考是用在整理和分析数据。在动笔前,详细讨论几遍写作提纲会提高写作效率;写很多遍正文反倒很慢。
All the writing that I do - papers, reports, proposals (and, of course, slides for seminars)- I do from outlines. I urge you to learn how to use them as well.
我写的所有文章,包括论文,报告, 建议(当然还有讨论会的胶片)都从提纲开始。我也希望你们能学会使用它。
How should you construct an outline? The classical approach is to start with a blank piece of paper, and write down, in any order, all important ideas that occur to you concerning the paper. Ask yourself the obvious questions:“Why did I do this work?” “What does it mean?”“What hypothesis did I mean to test?”“What ones did I actually test?”“What were the results?”“Did the work yield a new method or compound? What?”“What measurements did I make?”“What compounds? How were they characterized?” Sketch possible equations, figures, and schemes. It is essential to try to get the major ideas written down. If you start the research to test one hypothesis, and decide, when you see what you have, that the data really seem to test some other hypothesis better, don't worry. Write them both down, and pick the best combinations of hypotheses, objectives and data. Often the objectives of a paper when it is finished are different from those used to justify starting the work. Much of good science is opportunistic and revisionist.
你应该如何起草你的提要?最经典的方法就是找一页空白的纸,以任何顺序,写下与这篇文章有关的所有重要观点。自问一些显而易见的问题:为什么我要做这项工作?它意味着什么? 我要验证哪些假设? 我究竟验证了哪些假设? 结果如何? 这项工作产生了新方法或新物质吗?都是什么?我都做了那些测试?什么化合物? 它们是如何表征的?展示相关的方程,图表和示意图。试着写出主要的观点。如果你的研究开始是为证实一个假设,然而当你发现你有的数据仿佛真的可以更好地验证其它的假设时,你也不必担心。把它们两者都写出来,去选择假设,目的和数据的最佳组合。时常,当一篇文章完成时,它的目的和开始时是不同的。许多好的科学来自机遇和反复修正。
When you have written down what you can, start with another piece of paper and try to organize the jumble of the first one. Sort all of your ideas into three major heaps (A-C).
当你已经写下你能写的,再拿出一页纸,试着草拟一份提纲。将你的观点分成三大类(见A,B,C)
A) Introduction
Why did I do the work? What were the central motivations and hypotheses?
A)引言
为什么我要做这件工作,主要的目的和假设是什么?
B) Results and Discussion
What were the results? How were compounds made and characterized? What was measured?
B)结果和讨论
结果是什么?化合物是怎样合成与表征的?测试方法是什么?
C) Conclusions
What does it all mean? What hypotheses were proved or disproved? What did I learn? Why does it make a difference?
C)结论
所有这一切意味着什么?证实或否定了什么假设?我学到了什么?结果为什么与众不同?
Next, take each of these sections, and organize it on yet finer scale. Concentrate on organizing the data. Construct figures, tables, and schemes to present the data as clearly and compactly as possible. This process can be slow - I may sketch a figure 5-10 times in different ways, trying to decide how it is most clear (and looks best aesthetically).
接下来, 把每一部分再仔细组织。尤其是要集中整理数据。要尽可能把数据以清晰、紧凑的图表来展示。这个过程也许会慢些。我可能要用5~10次,而且是以不同的方式,来构思一张图,以便决定怎样它才最清楚(而且看上去更加美观)。
Finally, put everything-outline of sections, tables, sketches of figures, equations - in good order.
最后,把所有这些-内容的提纲、表格、草图、方程式,排好顺序。
When you are satisfied that you have included all the data (or that you know what additional data you intend to collect), and have a plausible organization, give the outline to me. Simply indicate where missing data will go, how you think (hypothesize) they will look, and how you will interpret them if your hypothesis is correct. I will take this outline, add my opinions, suggest changes, and return it to you. It usually takes 4-5 repeated attempts (often with additional experiments) to agree on an outline. When we have agreed, the data are usually in (or close to) final form (that is, the tables, figures, etc., in the outline will be the tables, figures,…in the paper.)
当你已经囊括了所有的数据(或者你明确知道你还需要收集哪些额外的数据),有了一个合理的构架,你对这些都感到满意时,将大纲交给我。简要地标明哪些地方还缺数据,你认为(或推测)这些数据大概是什么样。如果你的推测是正确的,你将如何去解释它。拿到你的大纲后,我将把我的观点,建议反馈给你。一般,我们需要四或五个来回才能达成一致(中间经常还需要补做一些实验)。在我们的意见一致后,所有的数据通常以最终(或接近最终的)形式确定下来(也就是说,在提纲中的表格,图表等最终将成为文章中的表格,图表)。
