主题:【咨询】想买台安捷伦1260,下面的报价合理吗,请大侠给点建议!
浏览0 回复11 电梯直达
wgzcell
想买台安捷伦1260,
代理商报价如下,请高手看看合理吗,有哪些配件/耗材可以增减?望高手多多指点,谢谢!
安捷伦1260 制备液相色谱系统二极管阵列检测器)
ITEMPART NO.&DESCRIPTIONUNIT(US$)QTYTOTAL( US$ )
泵单元
1G1361A 高压制备泵23,981.25123,981.25
Agilent 1260 Infinity Preparative PumpIncludes preparative pump, solvent cabinet, solvent bottle 2 l, purge valve, 1-m CAN cable and seal wash with peristaltic pump.
2G1391A  高压制备泵梯度扩展泵23,981.25123,981.25
Agilent 1260 Infinity Preparative pump gradient extensionIncludes preparative pump, gradient kit, solvent bottle 2 l, purge valve, 0.5-m CAN cable and seal wash with peristaltic pump.
自动进样器
1G2260A  制备型自动进样器(标配2mL定量环)20,582.50120,582.50
Agilent 1260 Infinity Preparative Autosampler
2G2260-68711  5mL定量环522.501522.50
5ml Multi draw loop for use with G2260A
馏分收集器
1G1364B  制备型自动馏分收集器13,857.86113,857.86
Agilent 1260 Fraction Collector (Preparative scale). Includes delay sensor
2G1364-84523  样品盘528.751528.75
Tray holding 40 tubes, 30 x 100mm, 50ml
3G1364-84525 样品盘528.751528.75
Tray holding 126 tubes, 16x100mm,14ml
45042-6458  样品瓶66.07166.07
Round bottom glass vial, 30x100mm 100/PK
55022-6532  样品瓶62.50162.50
Test Tube, 16 x 100 mm, 250/pk
检测器
1G1315D  二极管阵列检测器19,510.36119,510.36
1260 Infinity Diode Array Detector VL. Provides 20 Hz data acquisition rate and RFID tags for flow cell and lamp. Includes RFID tracking technology for flow cells and UV lamp. No flow cell included.
2G1315D-024  制备流通池2,868.7512,868.75
Prep flow cell 0.3mm 20 bar quartz
软件
1M8307AA  液相色谱化学工作站操作软件(中英文可选)8,636.6518,636.65
ChemStation for liquid chromatography. For control, data acquisition and evaluation of chromatographic data from one liquid chromatograph(含光谱软件).
色谱柱
1883975-202  SB-C18 色谱柱, 9.4 x 150 mm5u  1556.25 11,556.25
SB-C18, 5um, 9.4 x 150 mm
2870150-902 -C18 色谱柱, 21.2x150mm,5u3210.00 13,210.00
PrepHT ,SB-C18,21.2x150mm,5u Crt
3840140-901    半制备柱保护柱卡套383.75 1383.75
Semiprep Guard Hardware Kit
4820675-115    半制备柱保护柱柱芯340.00 1340.00
SB-C8 Prep Reliance Grd Col 9.4x15 2/PK
5820400-901   制备柱卡套453.75 1453.75
PrepHT,Hardware,21.2mm Crt.End Ftg 2/PK BC
6820444-901   制备柱保护柱卡套428.75 1428.75
PrepHT Guard Hardware Kit BC 263.00
7820212-920   制备柱保护柱柱芯472.50 1472.50
PrepHT ZORBAX SB-C18 Grd Crt, 5um 2/PK
备件及耗材
1G1361-60012  出入口单向阀芯145.002290.00
Valve assy, inlet/outlet for prep pump
2G1361-60006  过滤组件742.371742.37
Filter Screw  Multi AY
35065-9926  不锈钢毛细软管204.901204.90
Flex capillary,0.5×800mm no fittings
45062-2462  聚四氟乙烯管线46.13146.13
Teflon tubing.7mm id,1.6mm od,5m
55062-2418  不锈钢接头205.001205.00
1/16" Fittings and Ferrules  10/PK
601018-22707  过滤白头,5/43.42143.42
PTFE Frits 5PK
73150-0944  制备型溶剂入口过滤头67.73167.73
Glass filter, solvent inlet, 40um
82140-0813 长寿命氘灯1,323.7511,323.75
Deut. lamp, 1100/1200DAD/MWD lnglife-A
95182-0714  旋口样品瓶,100/28.21128.21
Screw cap vials, clear  100/PK
105182-0728螺纹口样品瓶盖,100/15.04115.04
Blue screw caps  100/PK
115182-0731 螺纹口样品瓶垫,100/20.29120.29
Septa, PTFE/red silicone, 8.7mm 100/pk
Total List Price:US$              124,959.03
Freight & Insurance:US$                  6,247.95
Total Net Price:US$        131,206.98
杨小茅
huaibeijiayuan
这里的耗材都是必须的,不但不能减,有的有必要增加,前提是不增加增体费用(要求赠送)。
richies
看到了这么清晰报价,基本上可以这样说,LZ还价的空间很小了
张耗材
还算合理吧,但是应该能再优惠点,我邮箱,有事可以互相交流下
2013/4/6 23:03:52 Last edit by fengmo4668
秋醉虞阳
richies
原文由 秋醉虞阳(wangjianhua1102) 发表:
这个应该还可以优惠
都拿到A的标准报价了,肯定被人入了FUNNEL了,还怎么谈
hza123
秋醉虞阳
原文由 richies(richies) 发表:
这个应该还可以优惠
拿岛津的比价
richies
这个应该还可以优惠
拿岛津的比价
你准备陪标去?
秋醉虞阳
这个应该还可以优惠
拿岛津的比价
你准备陪标去?
不陪标。不是俺的,俺不管
