原文由 wangm 发表:
文献上看见一个简单的解释是;
CSA(chemical shift anisotropy) is defined as the chemical shift difference between the isotropic and anisotropic states.
一点没看懂
汪茂田 译注
APT Attached Proton Test 质子连接实验
ASIS Aromatic Solvent Induced Shift 芳香溶剂诱导位移
BBDR Broad Band Double Resonance 宽带双共振
BIRD Bilinear Rotation Decoupling 双线性旋转去偶(脉冲)
COLOC Correlated Spectroscopy for Long Range Coupling 远程偶合相关谱
COSY ( Homonuclear chemical shift ) COrrelation SpectroscopY (同核化学位移)相关谱
CP Cross Polarization 交叉极化
CP/MAS Cross Polarization / Magic Angle Spinning 交叉极化魔角自旋
CSA Chemical Shift Anisotropy 化学位移各向异性
CSCM Chemical Shift Correlation Map 化学位移相关图
CW continuous wave 连续波
DD Dipole-Dipole 偶极-偶极
DECSY Double-quantum Echo Correlated Spectroscopy 双量子回波相关谱
DEPT Distortionless Enhancement by Polarization Transfer 无畸变极化转移增强
2DFTS two Dimensional FT Spectroscopy 二维傅立叶变换谱
DNMR Dynamic NMR 动态NMR
DNP Dynamic Nuclear Polarization 动态核极化
DQ(C) Double Quantum (Coherence) 双量子(相干)
DQD Digital Quadrature Detection 数字正交检测
DQF Double Quantum Filter 双量子滤波
DQF-COSY Double Quantum Filtered COSY 双量子滤波COSY
DRDS Double Resonance Difference Spectroscopy 双共振差谱
EXSY Exchange Spectroscopy 交换谱
FFT Fast Fourier Transformation 快速傅立叶变换
FID Free Induction Decay 自由诱导衰减
H,C-COSY 1H,13C chemical-shift COrrelation SpectroscopY 1H,13C化学位移相关谱
H,X-COSY 1H,X-nucleus chemical-shift COrrelation SpectroscopY 1H,X-核化学位移相关谱
HETCOR Heteronuclear Correlation Spectroscopy 异核相关谱
HMBC Heteronuclear Multiple-Bond Correlation 异核多键相关
HMQC Heteronuclear Multiple Quantum Coherence异核多量子相干
HOESY Heteronuclear Overhauser Effect Spectroscopy 异核Overhause效应谱
HOHAHA Homonuclear Hartmann-Hahn spectroscopy 同核Hartmann-Hahn谱
HR High Resolution 高分辨
HSQC
Heteronuclear Single Quantum Coherence 异核单量子相干
INADEQUATE Incredible Natural Abundance Double Quantum Transfer Experiment 稀核双量子转移实验(简称双量子实验,或双量子谱)
INDOR Internuclear Double Resonance 核间双共振
INEPT Insensitive Nuclei Enhanced by Polarization 非灵敏核极化转移增强
INVERSE H,X correlation via 1H detection 检测1H的H,X核相关
IR Inversion-Recovery 反(翻)转回复
JRES J-resolved spectroscopy J-分解谱
LIS Lanthanide (chemical shift reagent ) Induced Shift 镧系(化学位移试剂)诱导位移
LSR Lanthanide Shift Reagent 镧系位移试剂
MAS Magic-Angle Spinning 魔角自旋
MQ(C) Multiple-Quantum ( Coherence ) 多量子(相干)
MQF Multiple-Quantum Filter 多量子滤波
MQMAS Multiple-Quantum Magic-Angle Spinning 多量子魔角自旋
MQS Multi Quantum Spectroscopy 多量子谱
NMR Nuclear Magnetic Resonance 核磁共振
NOE Nuclear Overhauser Effect 核Overhauser效应(NOE)
NOESY Nuclear Overhauser Effect Spectroscopy 二维NOE谱
NQR Nuclear Quadrupole Resonance 核四极共振
PFG Pulsed Gradient Field 脉冲梯度场
PGSE Pulsed Gradient Spin Echo 脉冲梯度自旋回波
PRFT Partially Relaxed Fourier Transform 部分弛豫傅立叶变换
PSD Phase-sensitive Detection 相敏检测
PW Pulse Width 脉宽
RCT Relayed Coherence Transfer 接力相干转移
RECSY Multistep Relayed Coherence Spectroscopy 多步接力相干谱
REDOR Rotational Echo Double Resonance 旋转回波双共振
RELAY Relayed Correlation Spectroscopy 接力相关谱
RF Radio Frequency 射频
ROESY Rotating Frame Overhauser Effect Spectroscopy 旋转坐标系NOE谱
ROTO ROESY-TOCSY Relay ROESY-TOCSY 接力谱
SC Scalar Coupling 标量偶合
SDDS Spin Decoupling Difference Spectroscopy 自旋去偶差谱
SE Spin Echo 自旋回波
SECSY Spin-Echo Correlated Spectroscopy自旋回波相关谱
SEDOR Spin Echo Double Resonance 自旋回波双共振
SEFT Spin-Echo Fourier Transform Spectroscopy (with J modulation) (J-调制)自旋回波傅立叶变换谱
SELINCOR Selective Inverse Correlation 选择性反相关
SELINQUATE Selective INADEQUATE 选择性双量子(实验)
SFORD Single Frequency Off-Resonance Decoupling 单频偏共振去偶
SNR or S/N Signal-to-noise Ratio 信 / 燥比
SQF Single-Quantum Filter 单量子滤波
SR Saturation-Recovery 饱和恢复
TCF Time Correlation Function 时间相关涵数
TOCSY Total Correlation Spectroscopy 全(总)相关谱
TORO TOCSY-ROESY Relay TOCSY-ROESY接力
TQF Triple-Quantum Filter 三量子滤波
WALTZ-16 A broadband decoupling sequence 宽带去偶序列
WATERGATE Water suppression pulse sequence 水峰压制脉冲序列
WEFT Water Eliminated Fourier Transform 水峰消除傅立叶变换
ZQ(C) Zero-Quantum (Coherence) 零量子相干
ZQF Zero-Quantum Filter 零量子滤波
T1 Longitudinal (spin-lattice) relaxation time for MZ 纵向(自旋-晶格)弛豫时间
T2 Transverse (spin-spin) relaxation time for Mxy 横向(自旋-自旋)弛豫时间
tm mixing time 混合时间
τc rotational correlation time 旋转相关时间
本站的,
