13C observe with 31P decoupling,(and 1H decoupling)
Software setup:
Recall standard 13C parameters.
then type dn2=’P31’ dpwr2=45 dm2=’nny’ dmm2=’w’ homo2=’n’
determine and enter dof2=(your value) from the phosphorous spectrum
(only if proton decoupling is NOT wanted, type dm=’n’)
Hardware setup:
Remove the terminator from the cable labeled "Console Output #3".
Connect the cable to the filter "Bandpass 131-171 MHz".
Connect the band pass filter to one input of the power combiner box ("2-Way combiner").
Connect the filter "Bandpass 98-120 MHz" to the other input of the power combiner box.
Detach the cable between the probe (X-nucleus) and the "Magnet Console Interface Box" (MCIB) from the MCIB. Attach this end to the output of the power combiner box (third connector, opposite side).
Connect a new cable to the bandpass filter "98-120 MHz" and to the input at the magnet stand, from where you have just taken off the probe cable.
When you are done, you have to set the instrument back to standard conditions!
Here is how to:
Terminate the cable labeled "Console Output #3" with the big black terminator.
Connect the cable from the probe (X-nucleus) directly to the "Magnet Console Interface Box".
Deposit all extra electronics back onto the spectrometer console.
The software changes will be undone automatically, when you set up a new experiment.
13C observe with 19F decoupling, (no 1H decoupling possible)
Software setup:
then type dn=’F19’ dof=(your value determined from you 19F spectrum)
rf(3,1,2)
Hardware setup:
Place the big black 50 Ohm terminator from the cable labeled "Console Output #3" on to the cable labeled "Console Output #2", currently at the Magnet Console Interface Box (MCIB).
Connect the cable labeled "Console Output #3" to the input at the MCIB "B Band Amp" (from where you took the cable labeled "Console Output #2").
Open the right door of the console. In the upper right corner you find three boards labeled XMTR. Move the lowest cable (J2X5) from the middle XMTR board to the equivalent BNC connector at the left board.
Here is how to:
Reconnect the cable labeled "Console Output #2" to the input at MCIG "B Band Amp" (from where you took off the cable labeled "Console Output #3").
Change the cabling in the console back from the left to the middle XMTR board
31P observe with 19F decoupling, (no 1H decoupling possible)
Software setup:
Recall standard 31P parameters.
rf(3,1,2)
Hardware setup:
Here is how to:
