主题:【求助】请教吸附脱附数据如何分析?
浏览0 回复0 电梯直达
danfu2006
        以下为经加工的粘土样品吸附脱附数据,依此判断该样属于微孔、介孔还是微孔-介孔?在BET Surface Area、 Langmuir Surface Area、 t-Plot Micropore Area、t-Plot External Surface Area这些数据中,哪种比表面积更能准确反映该样的吸附特性?还有其它哪些数据能反映该样的吸附特性?谢谢!
    Started:    6/10/2013 8:08:37        Analysis Adsorptive:    N2
          Completed:    6/10/2013 13:31:56      Analysis Bath Temp.:    77.368 K
        Report Time:    6/11/2013 15:14:57        Thermal Correction:    No
        Sample Mass:    0.2489 g                    Warm Free Space:    15.3849 cm?Measured
    Cold Free Space:    45.6228 cm?          Equilibration Interval:    10 s
  Low Pressure Dose:    None                        Automatic Degas:    Yes
Summary Report
                            Surface Area
  Single point surface area at P/Po = 0.200349203:    60.1343 m?g
                                BET Surface Area:    60.2688 m?g
                            Langmuir Surface Area:    81.7684 m?g
                            t-Plot Micropore Area:    23.1415 m?g
                    t-Plot External Surface Area:    37.1273 m?g
  BJH Adsorption cumulative surface area of pores
      between 1.7000 nm and 300.0000 nm diameter:    34.238 m?g
  BJH Desorption cumulative surface area of pores
      between 1.7000 nm and 300.0000 nm diameter:    56.1240 m?g
                              Pore Volume
  Single point adsorption total pore volume of pores
  less than 66.8605 nm diameter at P/Po = 0.970190755:    0.085403 cm?g
                              t-Plot micropore volume:    0.010483 cm?g
            BJH Adsorption cumulative volume of pores
          between 1.7000 nm and 300.0000 nm diameter:    0.114678 cm?g
            BJH Desorption cumulative volume of pores
          between 1.7000 nm and 300.0000 nm diameter:    0.124415 cm?g
                          Pore Size
  Adsorption average pore width (4V/A by BET):    5.66816 nm
  BJH Adsorption average pore diameter (4V/A):    13.3978 nm
  BJH Desorption average pore diameter (4V/A):    8.8671 nm
  ASAP 2020 V3.04 H    Unit 1    Serial #: 1043    Page  1
    Sample:    13
  Operator:
  Submitter:
      File:    F:\20135~1.25\13.SMP
                    Isotherm Tabular Report
                              Quantity
  Relative      Absolute    Adsorbed    Elapsed    Saturation
  Pressure      Pressure      (cm?g      Time      Pressure
    (P/Po)        (mmHg)        STP)      (h:min)      (mmHg)
  1.#QNAN0000      1.#QNAN0      1.#QNB      01:01    761.002197
  0.009539390      7.260718    12.1028      01:23      1.#QNAN0
  0.030092658    22.905132    13.6231      01:27      1.#QNAN0
  0.065439628    49.810745    14.8200      01:30      1.#QNAN0
  0.079626204    60.610546    15.1679      01:33      1.#QNAN0
  0.100018045    76.133743    15.6031      01:35      1.#QNAN0
  0.120068489    91.398239    15.9803      01:38      1.#QNAN0
  0.140053697    106.612961    16.3312      01:40      1.#QNAN0
  0.160210168    121.958519    16.6593      01:42      1.#QNAN0
  0.180698859    137.558502    16.9805      01:45      1.#QNAN0
  0.200349203    152.519821    17.2748      01:47      1.#QNAN0
  0.248862267    189.454254    17.9749      01:49      1.#QNAN0
  0.301234540    229.329559    18.7145      01:52      1.#QNAN0
  0.351589565    267.670929    19.4120      01:55      1.#QNAN0
  0.400171434    304.664093    20.0701      01:58      1.#QNAN0
  0.450088331    342.672760    20.7400      02:00      1.#QNAN0
  0.500166664    380.808411    21.4173      02:03      1.#QNAN0
  0.550061166    418.802643    22.1197      02:05      1.#QNAN0
  0.599945148    456.793518    22.8802      02:08      1.#QNAN0
  0.649845479    494.798584    23.7639      02:11      1.#QNAN0
  0.699671756    532.744934    24.8203      02:13      1.#QNAN0
  0.749574146    570.754761    26.1482      02:16      1.#QNAN0
  0.799385514    608.697021    27.9263      02:19      1.#QNAN0
  0.820554612    624.830688    28.8913      02:22      1.#QNAN0
  0.849644418    646.996643    30.5405      02:25      1.#QNAN0
  0.874364267    665.840942    32.3960      02:29      1.#QNAN0
  0.899090699    684.691406    34.9499      02:33      1.#QNAN0
  0.923537431    703.335388    38.7257      02:38      1.#QNAN0
  0.947667443    721.750610    44.7008      02:45      1.#QNAN0
  0.970190755    738.960999    55.2129      02:55      1.#QNAN0
  0.981193761    747.393005    63.7139      03:04      1.#QNAN0
  1.#QNAN0000      1.#QNAN0      1.#QNB      03:05    761.723877
  0.989556084    753.757690    72.9863      03:15      1.#QNAN0
  0.996180179    758.791382    81.0618      03:26      1.#QNAN0
  0.982833707    748.619995    77.1236      03:31      1.#QNAN0
  0.973477052    741.486694    72.9823      03:37      1.#QNAN0
  0.952911940    725.813110    65.5153      03:46      1.#QNAN0
  0.923433657    703.352051    58.3174      03:54      1.#QNAN0
  0.904316344    688.785034    54.7753      04:00      1.#QNAN0
  0.876856386    667.864990    50.5820      04:05      1.#QNAN0
  0.850451592    647.747986    47.3404      04:11      1.#QNAN0
  0.825975972    629.102478    44.8408      04:15      1.#QNAN0
  0.800715138    609.859131    42.6015      04:19      1.#QNAN0
  0.750082838    571.292114    39.0126      04:23      1.#QNAN0
  0.700672609    533.656311    36.3043      04:27      1.#QNAN0
  0.651374086    496.106018    34.1354      04:31      1.#QNAN0
  0.600738415    457.537750    32.3277      04:35      1.#QNAN0
  0.550715235    419.437012    30.8240      04:38      1.#QNAN0
  0.501062063    381.617859    29.3391      04:42      1.#QNAN0
  0.453336748    345.265442    21.2756      04:50      1.#QNAN0
  0.399180356    304.018127    20.2440      04:53      1.#QNAN0
  0.333213726    253.776459    19.3291      04:56      1.#QNAN0
  0.300865087    229.138992    18.8824      04:58      1.#QNAN0
  0.250002355    190.401093    18.1866      05:01      1.#QNAN0
  0.200032521    152.343552    17.4823      05:04      1.#QNAN0
  1.#QNAN0000      1.#QNAN0      1.#QNB      05:06    761.591736
  0.140233460    106.800644    16.5655      05:09      1.#QNAN0
    Sample:    13
  Operator:
  Submitter:
Isotherm Linear Plot
13 - Adsorption
Relative Pressure (P/Po)    Quantity Adsorbed (cm?g STP)
0.00953939           12.1028
0.0300927           13.6231
0.0654396           14.82
0.0796262           15.1679
0.100018             15.6031
0.120068             15.9803
0.140054             16.3312
0.16021             16.6593
0.180699             16.9805
0.200349             17.2748
0.248862             17.9749
0.301235             18.7145
0.35159             19.412
0.400171             20.0701
0.450088             20.74
0.500167             21.4173
0.550061             22.1197
0.599945             22.8802
0.649845             23.7639
0.699672             24.8203
0.749574             26.1482
0.799386             27.9263
0.820555             28.8913
0.849644             30.5405
0.874364             32.396
0.899091             34.9499
0.923537             38.7257
0.947667             44.7008
0.970191             55.2129
0.981194             63.7139
0.989556             72.9863
0.99618             81.0618
13 - Desorption
0.99618             81.0618
0.982834             77.1236
0.973477             72.9823
0.952912             65.5153
0.923434             58.3174
0.904316             54.7753
0.876856             50.582
0.850452             47.3404
0.825976             44.8408
0.800715             42.6015
0.750083             39.0126
0.700673             36.3043
0.651374             34.1354
0.600738             32.3277
0.550715             30.824
0.501062             29.3391
0.453337             21.2756
0.39918             20.244
0.333214             19.3291
0.300865             18.8824
0.250002             18.1866
0.200033             17.4823
0.140233             16.5655
    Sample:    13
  Operator:
  Submitter:
Isotherm Log Plot
13 - Adsorption
0.00953939           12.1028
0.0300927           13.6231
0.0654396           14.82
0.0796262           15.1679
0.100018             15.6031
0.120068             15.9803
0.140054             16.3312
0.16021             16.6593
0.180699             16.9805
0.200349             17.2748
0.248862             17.9749
0.301235             18.7145
0.35159             19.412
0.400171             20.0701
0.450088             20.74
0.500167             21.4173
0.550061             22.1197
0.599945             22.8802
0.649845             23.7639
0.699672             24.8203
0.749574             26.1482
0.799386             27.9263
0.820555             28.8913
0.849644             30.5405
0.874364             32.396
0.899091             34.9499
0.923537             38.7257
0.947667             44.7008
0.970191             55.2129
0.981194             63.7139
0.989556             72.9863
0.99618             81.0618
13 - Desorption
0.99618             81.0618
0.982834             77.1236
0.973477             72.9823
0.952912             65.5153
0.923434             58.3174
0.904316             54.7753
0.876856             50.582
0.850452             47.3404
0.825976             44.8408
0.800715             42.6015
0.750083             39.0126
0.700673             36.3043
0.651374             34.1354
0.600738             32.3277
0.550715             30.824
0.501062             29.3391
0.453337             21.2756
0.39918             20.244
0.333214             19.3291
0.300865             18.8824
0.250002             18.1866
0.200033             17.4823
0.140233             16.5655
    Sample:    13
  Operator:
  Submitter:
                      BET Surface Area Report
                BET Surface Area:    60.2688 ?0.4559 m?g
                          Slope:    0.072313 ?0.000541 g/cm?STP
                    Y-Intercept:    -0.000083 ?0.000075 g/cm?STP
                              C:    -866.303186
                              Qm:    13.8447 cm?g STP
        Correlation Coefficient:    0.9998320
  Molecular Cross-Sectional Area:    0.1620 nm?
                Quantity
  Relative      Adsorbed
  Pressure      (cm?g    1/[Q(Po/P
    (P/Po)        STP)        - 1)]
  0.065439628    14.8200      0.004725
  0.079626204    15.1679      0.005704
  0.100018045    15.6031      0.007123
  0.120068489    15.9803      0.008539
  0.140053697    16.3312      0.009973
  0.160210168    16.6593      0.011452
  0.180698859    16.9805      0.012989
  0.200349203    17.2748      0.014504
    Sample:    13
  Operator:
  Submitter:
BET Surface Area Plot
13
Relative Pressure (P/Po)    1/[Q(Po/P - 1)]
0.0654396           0.00472483
0.0796262           0.00570381
0.100018             0.0071225
0.120068             0.00853878
0.140054             0.00997253
0.16021             0.0114515
0.180699             0.0129885
0.200349             0.0145035
    Sample:    13
  Operator:
  Submitter:
                            t-Plot Report
                Micropore Volume:    0.010483 cm?g
                          Slope:    24.002664 ?0.297823 cm?g穘m STP
                    Y-Intercept:    6.777030 ?0.121069 cm?g STP
        Correlation Coefficient:    0.999538
  Surface Area Correction Factor:    1.000
      Density Conversion Factor:    0.0015468
        Total Surface Area (BET):    60.2688 m?g
                Thickness Range:    0.35000 nm to 0.50000 nm
              Thickness Equation:    Harkins and Jura
  t = [ 13.99 / ( 0.034 - log(P/Po) ) ] ^ 0.5
                                Quantity
  Relative      Statistical    Adsorbed
  Pressure      Thickness      (cm?g
    (P/Po)          (nm)          STP)
  0.009539390        0.26095    12.1028
  0.030092658        0.29989    13.6231
  0.065439628        0.33889    14.8200
  0.079626204        0.35140    15.1679
  0.100018045        0.36785    15.6031
  0.120068489        0.38283    15.9803
  0.140053697        0.39699    16.3312
  0.160210168        0.41072    16.6593
  0.180698859        0.42431    16.9805
  0.200349203        0.43711    17.2748
  0.248862267        0.46826    17.9749
  0.301234540        0.50202    18.7145
  0.351589565        0.53545    19.4120
  0.400171434        0.56923    20.0701
  0.450088331        0.60620    20.7400
  0.500166664        0.64634    21.4173
  0.550061166        0.69030    22.1197
  0.599945148        0.73941    22.8802
  0.649845479        0.79529    23.7639
    Sample:    13
  Operator:
  Submitter:
t-Plot
Harkins and Jura
13
Thickness (nm)    Quantity Adsorbed (cm?g STP)
0.351402             15.1679
0.367845             15.6031
0.382829             15.9803
0.396985             16.3312
0.410724             16.6593
0.424313             16.9805
0.43711             17.2748
0.468257             17.9749
Not Fitted Points
0.26095             12.1028
0.299894             13.6231
0.338889             14.82
0.502025             18.7145
0.535445             19.412
0.569234             20.0701
0.6062               20.74
0.64634             21.4173
0.690302             22.1197
0.739407             22.8802
0.795291             23.7639
    Sample:    13
  Operator:
  Submitter:
BJH Adsorption Pore Distribution Report
          Faas Correction
                Halsey
  t = 3.54 [ -5 / ln(P/Po) ] ^ 0.333
                      Diameter Range:    1.7000 nm to 300.0000 nm
            Adsorbate Property Factor:    0.95300 nm
  Fraction of Pores Open at Both Ends:    0.00
                              Incremental    Cumulative                  Cumulative
                  Average        Pore          Pore      Incremental      Pore
  Pore Diameter    Diameter      Volume        Volume      Pore Area        Area
  Range (nm)        (nm)        (cm?g)      (cm?g)        (m?g)        (m?g)
  505.7 - 187.1      224.5      0.013129      0.013129          0.234        0.234
  187.1 - 104.9      124.2      0.015327      0.028456          0.494        0.728
  104.9 - 66.9        77.6      0.014314      0.042770          0.738        1.465
    66.9 - 38.7        45.5      0.018265      0.061035          1.607        3.072
    38.7 - 26.8        30.5      0.010519      0.071553          1.379        4.451
    26.8 - 20.5        22.7      0.006720      0.078274          1.182        5.633
    20.5 - 16.6        18.1      0.004563      0.082837          1.010        6.643
    16.6 - 13.9        15.0      0.003324      0.086162          0.887        7.531
    13.9 - 11.7        12.6      0.002965      0.089127          0.941        8.472
    11.7 - 10.5        11.0      0.001735      0.090862          0.629        9.101
    10.5 -  8.4        9.2      0.003238      0.094100          1.404        10.505
    8.4 -  7.0        7.6      0.002415      0.096515          1.272        11.777
    7.0 -  6.0        6.4      0.001924      0.098438          1.195        12.971
    6.0 -  5.2        5.6      0.001615      0.100054          1.160        14.132
    5.2 -  4.6        4.9      0.001394      0.101447          1.141        15.272
    4.6 -  4.1        4.3      0.001334      0.102781          1.231        16.503
    4.1 -  3.7        3.9      0.001354      0.104135          1.397        17.900
    3.7 -  3.3        3.5      0.001424      0.105559          1.635        19.535
    3.3 -  3.0        3.2      0.001486      0.107045          1.886        21.420
    3.0 -  2.7        2.9      0.001665      0.108710          2.335        23.755
    2.7 -  2.5        2.6      0.001831      0.110540          2.848        26.602
    2.5 -  2.2        2.3      0.001749      0.112289          3.015        29.618
    2.2 -  2.1        2.2      0.000735      0.113025          1.356        30.974
    2.1 -  2.0        2.1      0.000820      0.113845          1.580        32.554
    2.0 -  1.9        2.0      0.000833      0.114678          1.684        34.238
    Sample:    13
  Operator:
  Submitter:
BJH Adsorption Cumulative Pore Volume
Halsey : Faas Correction
13
Pore Diameter (nm)    Pore Volume (cm?g)
187.062             0.0131285
104.923             0.0284558
66.8605             0.0427695
38.6625             0.0610348
26.7728             0.0715535
20.4702             0.0782738
16.558               0.0828371
13.9118             0.0861615
11.7129             0.0891268
10.5039             0.0908622
8.44331             0.0940999
7.04166             0.0965148
6.02347             0.0984383
5.24379             0.100054
4.62495             0.101447
4.1184               0.102781
3.69181             0.104135
3.32705             0.105559
3.01571             0.107045
2.72729             0.10871
2.4545               0.11054
2.21861             0.112289
2.12589             0.113025
2.03003             0.113845
1.93577             0.114678
    Sample:    13
  Operator:
  Submitter:
BJH Adsorption dV/dD Pore Volume
13
Pore Diameter (nm)    Pore Volume (cm?g穘m)
224.536             4.11963e-005
124.197             0.000186602
77.6317             0.000376058
45.4748             0.00064775
30.5115             0.000884689
22.7365             0.00106628
18.0703             0.00116643
14.9842             0.0012563
12.6041             0.00134856
11.0346             0.00143537
9.22201             0.00157123
7.59673             0.00172288
6.43954             0.0018892
5.56919             0.00207175
4.8872               0.00225204
4.33539             0.00263307
3.87581             0.00317323
3.48519             0.00390485
3.15151             0.00477207
2.85234             0.00577192
2.57155             0.00671083
2.32019             0.00741458
2.16948             0.00793211
2.07483             0.00855236
1.9797               0.00883956
    Sample:    13
  Operator:
  Submitter:
BJH Adsorption dV/dlog(D) Pore Volume
13
Pore Diameter (nm)    dV/dlog(D) Pore Volume (cm?g放)
224.536             0.0303939
124.197             0.0610371
77.6317             0.0731407
45.4748             0.0767835
30.5115             0.0659081
22.7365             0.05765
18.0703             0.0495398
14.9842             0.0439595
12.6041             0.0396868
11.0346             0.0366778
9.22201             0.0341389
7.59673             0.030631
6.43954             0.0283594
5.56919             0.0268317
4.8872               0.0255536
4.33539             0.0264752
3.87581             0.0285048
3.48519             0.0315257
3.15151             0.0348194
2.85234             0.0381311
2.57155             0.0399981
2.32019             0.0398574
2.16948             0.0396687
2.07483             0.040913
1.9797               0.040352
    Sample:    13
  Operator:
  Submitter:
BJH Desorption Pore Distribution Report
          Faas Correction
                Halsey
  505.7 - 114.7      133.0      0.006541      0.006541          0.197        0.197
  114.7 - 74.9        86.6      0.006977      0.013518          0.322        0.519
    74.9 - 42.8        50.5      0.013019      0.026537          1.032        1.551
    42.8 - 26.7        31.1      0.012985      0.039523          1.673        3.224
    26.7 - 21.5        23.5      0.006512      0.046035          1.107        4.331
    21.5 - 16.9        18.6      0.007924      0.053959          1.705        6.035
    16.9 - 14.0        15.1      0.006259      0.060218          1.656        7.691
    14.0 - 12.0        12.9      0.004910      0.065128          1.528        9.220
    12.0 - 10.6        11.2      0.004480      0.069607          1.601        10.821
    10.6 -  8.4        9.2      0.007360      0.076968          3.189        14.010
    8.4 -  7.0        7.6      0.005641      0.082608          2.969        16.979
    7.0 -  6.0        6.4      0.004559      0.087167          2.829        19.808
    6.0 -  5.2        5.6      0.003792      0.090959          2.725        22.533
    5.2 -  4.6        4.9      0.003141      0.094100          2.577        25.110
    4.6 -  4.1        4.3      0.003309      0.097409          3.062        28.172
    4.1 -  3.7        3.9      0.026388      0.123797        27.240        55.412
    3.7 -  3.3        3.5      0.000618      0.124415          0.712        56.124
    Sample:    13
  Operator:
  Submitter:
BJH Desorption Cumulative Pore Volume
13
114.726             0.00654101
74.9192             0.0135179
42.8171             0.0265372
26.7173             0.0395227
21.5304             0.046035
16.8621             0.0539589
13.9644             0.0602175
12.0481             0.0651279
10.5522             0.0696074
8.44004             0.0769677
7.04508             0.0826084
6.03031             0.087167
5.23446             0.0909586
4.61195             0.0940997
4.10639             0.0974085
3.69714             0.123797
3.3                 0.124415
    Sample:    13
  Operator:
  Submitter:
BJH Desorption dV/dD Pore Volume
13
133.038             1.6729e-005
86.6128             0.000175268
50.4523             0.000405559
31.0544             0.000806561
23.5338             0.00125554
18.5912             0.00169736
15.1172             0.00215984
12.8505             0.00256244
11.1897             0.0029946
9.23323             0.0034847
7.59857             0.00404363
6.44568             0.00449221
5.56552             0.0047642
4.87557             0.00504592
4.3231               0.00654489
3.87492             0.0644792
3.46995             0.00155527
    Sample:    13
  Operator:
  Submitter:
BJH Desorption dV/dlog(D) Pore Volume
13
133.038             0.0101529
86.6128             0.0376988
50.4523             0.0535827
31.0544             0.063398
23.5338             0.0694724
18.5912             0.0746539
15.1172             0.076427
12.8505             0.0766007
11.1897             0.0778042
9.23323             0.07588
7.59857             0.071894
6.44568             0.067488
5.56552             0.0616843
4.87557             0.0571247
4.3231               0.0656197
3.87492             0.578759
3.46995             0.0125154
