主要包括:
Method 1010A:Pensky-Martens Closed-Cup Method for Determining Ignitability
Method 1020B:Setaflash Closed-Cup Method for Determining Ignitability
Method 1030:Ignitability of Solids
Method 1110A:Corrosivity Toward Steel
Method 1120:Dermal Corrosion
Method 1310B:Extraction Procedure (EP) Toxicity Test Method and Structural Integrity Test
Method 1311:Toxicity Characteristic Leaching Procedure
Method 1312: Synthetic Precipitation Leaching Procedure
Method 1320: Multiple Extraction Procedure
Method 1330A:Extraction Procedure for Oily Wastes
Method 1614: Brominated diphenyl ethers in water, soil, sediment,and tissue by HRGC/HRMS
EPA1000注:在六楼的附件中已经上传了压缩包,可以下载!
