主题:【求助】求助:哪家检测实验室可以承接厄贝沙坦检测
浏览0 回复7 电梯直达
jljmouse2003
按照EP药典配置检测API中所含有的杂质B---Azide
系统要求和检测方法:
Impurity B. Liquid chromatography (2.2.29).
Test solution. Dissolve 0.100 g of the substance to be examined in the mobile phase and dilute to 5.0 mL with the mobile phase.
Reference solution. Dissolve 25.0 mg of sodium azide R (sodium salt of impurity B) in the mobile phase and dilute to 100.0 mL with the mobile phase. Dilute 0.25 mL of this solution to 200.0 mL with the mobile phase.
Column:
size: l = 0.25 m, Ø = 4 mm;
stationary phase: strongly basic anion-exchange resin for chromatography R (8.5 µm).
Mobile phase: 4.2 g/L solution of sodium hydroxide R in carbon dioxide-free water R.
Flow rate: 1.0 mL/min.
Detection: conductivity detector with a sensitivity of 3 µS; use a self-regenerating anion suppressor.
Neutralisation of the eluent: either chemical or electrochemical:
chemical: by continuous countercurrent circulation in a neutralising micromembrane, performed before detection:
neutralising solvent: 0.025 M sulfuric acid;
flow rate: 10 mL/min;
pressure: corresponding to about 100 kPa.
electrochemical: 300 mA (for example).
Injection: 200 µL.
Run time: 25 min.
Retention time: impurity B = about 14 min.
System suitability: reference solution:
signal-to-noise ratio: minimum 10 for the peak due to impurity B.
Limit:
impurity B: not more than the area of the corresponding peak in the chromatogram obtained with the reference solution (10 ppm).
jljmouse2003
据我司的分析大神讲,几年前国内没有这个配置的仪器,仪器公司都摇头,不得不开发了内控方法,请明白人指教:这个系统目前国内哪家仪器公司可以提供配置,以备日后采购设备。哪个实验室现在可以提供检测服务(结果被欧盟EDQM认可)。
peng_friend
cangyangjiacuo
站内有报告啊  厄贝沙坦药物中叠氮化物的检测  可以下载的 链接 http://www.instrument.com.cn/netshow/SH100311/s337162.htm
sunfire
这个简单啦 花点钱 送检就行啦 找您所在的省药检所就好
jljmouse2003
感谢,看了链接中的文献,是针对中国药典厄贝沙坦征求意见稿的,我写的方法是EP药典的/
bioengine
EP的柱子是戴安的IonPac AS10的柱子,基本处于停产状态。
EP的方法如果没问题,药检所的人也不会吃饱了没事去改。就是一针比一针提前很严重而且柱子很难冲洗,才会改成现在的方法。为了做你几个样就买一根柱子,谁愿意废这种成本?你一个样给多少钱?
colindrj
过反向柱后, 用as-18就可以做。
很多药厂就是用这个方法做的。
