主题:上传文章 关于TDLAS
浏览0 回复3 电梯直达
doublezha
文章题目:Progress in reducing size and cost of trace gas analyzer based on TDLAS
文档类型:PDF
希望对大家有用!
doublezha
liwutian
真实、文明的原则
2、《北京地区互联网站电子公告服务倡议书》
3、尊重网上道德,遵守《全国人大常委会关于维护互联网安全的决定》 及中华人民共和国其他有关法律法规
4、严禁发表危害国家安全、破坏民族团结、破坏国家宗教政策、破坏社会稳定、侮辱、诽谤、教唆、淫秽等内容的帖子
5、对于评论他人并引起争论、争议以及其他读者反感的帖子将删除。
6、散布无根据的舆论引起不良震动的帖子也将删除。
7、承担一切因您的行为而直接或间接导致的民事或刑事法律责任
8、版主有权保留或删除其管辖论坛中的任意内容,并且不作解释。
9、所有广告请在“仪器供求”论坛发布,其他版块广告一律删除,并且不作解
unisearch
Principle of Operation
The LasIR is based on the absorption of light in the near infrared region of the spectrum. What is unique to the LasIR is its very special light source, called a Tunable Diode Laser. These tiny devices are similar to the solid state lasers used in telecommunication and in consumer products such as laser printers and compact disc players. Laser diodes can be selected which are unique to a particular gas ensuring that the measurement is free from interferences from any other gas or particle.
Gases that can be Measured with the LasIR Include:
HF, HCl, HBr, HI, HCN, CO, CO2, CH4, C2H2, C2H4, C2H6, C3H8, CH2CHCl, NO, NO2, NH3, H2S, H2O, O2 ,D2O, HOD
Industries that are Using these Systems Include:
Aluminium     Semiconductor     Power
Generation     Specialty Gases     Natural Gas
Petrochemical     Landfills     Oil Refineries     Combustion     Geothermal
Incinerators     Sewage and
Waste
treatment     Pulp and Paper     Auto-exhaust     Cement
Glass     Fertilizer          Steel
Main Advantages
          o No interferences from other gases: TDLAS technology provides the most interference free method of any analytical technique.
          o No interference from particles: Measurements of gas
            concentrations are unaffected by the presence of particles,
            including rain and snow.
          o Fast time response: measurements can be made in less than 1
            second if desired.
          o High sensitivity: Sensitivities down to and below 1 ppbv
            depending on the path length
          o Fiber optic link for remote control: permits the instrument
            to be located long distances from the measurement point
          o Cost effective: multiplexing of fiber optic cables permit simultaneous measurement at a number of locations with the same instrument
          o Long Paths Lengths: up to 1 kilometer
          o Easy to install and rugged, maintenance-free operation
          o Can cover a broad range of concentrations
