保健品中双酚A类的测定解决方案
参考《SNT 3150-2012 出口食品中双酚A-二缩水甘油醚、双酚F-二缩水甘油醚及其衍生物残留测定液相色谱-质谱 质谱法》
(1)活 化: | 向柱中加入3 mL乙酸乙酯、3 mL甲醇、3 mL水,弃去流出液; |
(2)上 样: | 将待净化液加入柱中,弃去流出液; |
(3)淋 洗: | 向柱中加入3 mL 20%甲醇水,弃去流出液,抽干小柱; |
(4)洗 脱: | 向柱中加入5 mL 甲醇:乙酸乙酯(1:2),推干小柱,收集流出液; |
(5)重新溶解: | 将洗脱液在35℃水浴下减压蒸干,用50%甲醇水定容至1 mL,供HPLC分析。 |
时间/Min. | 10 | 25 | 30 | 75 |
A(%) | 60 | 40 | 60 | 60 |
B(%) | 40 | 60 | 40 | 40 |
NO. | 化合物名称 | 添加水平(mg/kg) | 回收率(%) |
1 | BFDGE-2H2O | 1.0 | 98.28 |
2 | BADGE-2H2O | 1.0 | 100.61 |
3 | BPA | 1.0 | 102.03 |
4 | BPF | 1.0 | 90.08 |
5 | BADGE-HCL-H2O | 0.1 | 104.38 |
6 | BADGE-H2O | 1.0 | 99.01 |
7 | BFDGE-2HCL | 1.0 | 93.98 |
8 | BISS | 1.0 | 94.55 |
9 | BFDGE | 1.0 | 94.15 |
10 | BADGE-2HCL | 1.0 | 99.79 |
11 | BADGE-HCL | 1.0 | 91.95 |
12 | BADGE | 3.0 | 96.59 |
1 | BFDGE-2H2O | 1.0 | 94.78 |
2 | BADGE-2H2O | 1.0 | 98.84 |
3 | BPA | 1.0 | 97.40 |
4 | BPF | 1.0 | 94.31 |
5 | BADGE-HCL-H2O | 0.1 | 105.08 |
6 | BADGE-H2O | 1.0 | 93.44 |
7 | BFDGE-2HCL | 1.0 | 99.47 |
8 | BISS | 1.0 | 96.42 |
9 | BFDGE | 1.0 | 103.77 |
10 | BADGE-2HCL | 1.0 | 98.88 |
11 | BADGE-HCL | 1.0 | 110.49 |
12 | BADGE | 3.0 | 107.41 |
[img=植物蛋白粉中双酚A类检测(空白样品)的液相色谱图.jpg]http://www.dikma.com.cn/u/image/2016/01/28/1453963867134762.jpg[/img]
[img=胶囊油中(添加水平BADGE-HCL-H2O为0.1 mg/kg、BADGE为3.0 mg/kg、其余为1.0 mg/kg)双酚A类检测的液相色谱图.jpg]http://www.dikma.com.cn/u/image/2016/01/28/1453963879111654.jpg[/img]
货号 | 名称 | 规格 |
样品前处理 | ||
65461 | ProElut CARB | 100 mg/3 mL, 50/pk |
244358 | 12管防交叉污染真空SPE萃取装置 | 12位 |
4803 | 1,3,6mL柱管通用连接器 | 15/pk |
4806 | 考克(控制流量) | 15/pk |
99011 | 真空/正压两用泵,无油 | 1/pk |
99013 | 抽滤瓶套装 (包括硅橡胶管2米,2L抽滤瓶及橡胶塞) | 1/pk |
30039 | FitMax针头式过滤器 Nylon | 13 mm,0.22 μm 100/pk |
30040 | FitMax针头式过滤器 Nylon | 13 mm,0.45 μm 100/pk |
标准品 | ||
56-15142-250MG | BFDGE-2H2O | 250 mg |
56-15137-250MG | BADGE-2H2O | 250 mg |
46611 | BPA | 1 g |
54-51453-100MG | BPF | 100 mg |
56-92427-100MG | BADGE-HCL-H2O | 100 mg |
56-73417-100MG | BADGE-H2O | 100 mg |
83A-B519545-10MG | BFDGE-2HCL | 10 mg |
12-NG-16792-1G | BISS | 1 g |
56-15144-500MG | BFDGE | 500 mg |
56-15136-250MG | BADGE-2HCL | 250 mg |
56-73124-100MG | BADGE-HCL | 100 mg |
56-15138-500MG | BADGE | 500 mg |
色谱柱及保护柱 | ||
99511 | Platisil PH | 250 × 4.6 mm,5 μm |
6203 | EasyGuard Phenyl 保护柱 | 10 × 4.0 mm 1/pk 2个柱芯+1个柱套 |
HPLC溶剂Ÿ缓冲盐Ÿ离子对试剂 | ||
50101 | 乙腈 HPLC级 | 4 L |
50102 | 甲醇 HPLC级 | 4 L |
50104 | 乙酸乙酯 HPLC级 | 4 L |
通用色谱产品 | ||
52401B | 瓶架/蓝色(现货) | 50孔 |
52401A | 瓶架/白色(现货) | 50孔 |
1034 | 样品瓶(棕色/螺纹) | 2 mL, 100/pk |
1035 | 样品瓶盖/含垫(已经组装) | 100/pk |
H80465 | HPLC 进样针 | 25 μL |
