主题:【求助】求助ASTM标准
浏览0 回复12 电梯直达
yuqi7231
求助以下ASTM 标准, 中英文均可, 感谢~
ASTM D1002, ASTM D1062, ASTM D1896, ASTM D2182, ASTM D3013, ASTM D3123, ASTM D3164, ASTM D5224, ASTM D5948, ASTM D897
穿越时空
frozenthrone
希望以下能帮到LZ
ASTM D1002 - 10
Standard Test Method for Apparent Shear Strength of Single-Lap-Joint Adhesively Bonded Metal Specimens by Tension Loading (Metal-to-Metal)
http://www.doc88.com/p-4953403601819.html
ASTM D1062 - 08(2015)
Standard Test Method for Cleavage Strength of Metal-to-Metal Adhesive Bonds
http://www.doc88.com/p-8899731690240.html
ASTM D1896 / D1896M - 10
Standard Practice for Transfer Molding Test Specimens of Thermosetting Compounds
网上流传最新为99版
http://www.doc88.com/p-8945287324526.html
ASTM D2182-72(1978) 金属对金属粘接压缩剪切强度的标准试验方法(圆盘剪切)
ASTM D2182-78
估计已废止
ASTM D3013 - 13
Standard Specification for Epoxy Molding Compounds
http://bbs.angui.org/thread-151056-1-1.html
ASTM D3123 - 09
Standard Test Method for Spiral Flow of Low-Pressure Thermosetting Molding Compounds
http://www.doc88.com/p-0008916821063.html
ASTM D3164 - 03(2011)
Standard Test Method for Strength Properties of Adhesively Bonded Plastic Lap-Shear Sandwich Joints in Shear by Tension Loading
网上流传最新版为03版
http://www.gfjl.org/thread-123028-1-1.html
http://bbs.myboyan.com/america/b160236/
ASTM D5224 - 12
Standard Practice for Compression Molding Test Specimens of Thermosetting Molding Compounds
http://www.doc88.com/p-1197698830935.html
ASTM D5948 - 05(2012)
Standard Specification for Molding Compounds, Thermosetting
http://bbs.angui.org/thread-145068-1-1.html
ASTM D897 - 08(2016)
Standard Test Method for Tensile Properties of Adhesive Bonds
网上流传最新版为08版
http://www.doc88.com/p-5466908582782.html
liuxilin1215
ASTM D897-08(R2016) Standard Test Method for Tensile Properties of Adhesive Bonds
如有侵权,请版主及时删除!
2016/11/25 21:10:15 Last edit by liuxilin1215
liuxilin1215
ASTM D5948-05(R2012) Standard Specification for Molding Compounds, Thermosetting
如有侵权,请版主及时删除!
liuxilin1215
ASTM D5224-12 Standard Practice for Compression Molding Test Specimens of Thermosetting Molding Compounds
如有侵权,请版主及时删除!
附件:
liuxilin1215
ASTM D3164-03(R2011) Standard Test Method for Strength Properties of Adhesively Bonded Plastic Lap-Shear Sandwich Joints in Shear by Tension Loading
如有侵权,请版主及时删除!
liuxilin1215
ASTM D3123-09 Standard Test Method for Spiral Flow of Low-Pressure Thermosetting Molding Compounds
如有侵权,请版主及时删除!
附件:
liuxilin1215
ASTM D3013-13 Standard Specification for Epoxy Molding Compounds
如有侵权,请版主及时删除!
附件:
liuxilin1215
ASTM D2812-07(R2012) Standard Test Method for Non-Lint Content of Cotton
如有侵权,请版主及时删除!
liuxilin1215
ASTM D1896/D1896M-10 Standard Practice for Transfer Molding Test Specimens of Thermosetting Compounds
如有侵权,请版主及时删除!
手机版: 求助ASTM标准
