ASTM D5197 - 09e1
Standard Test Method for Determination of Formaldehyde and Other Carbonyl Compounds in Air (Active Sampler Methodology)
http://www.doc88.com/p-2992377897124.html
ASTM D6196 - 15
Standard Practice for Choosing Sorbents, Sampling Parameters and Thermal Desorption Analytical Conditions for Monitoring Volatile Organic Chemicals in Air
手头暂时没有,网上流传最新版本为
ASTM D6196 - 03(R2009)
http://www.doc88.com/p-0973163999203.html
EPA Compendium Method TO-11A
https://www3.epa.gov/ttnamti1/files/ambient/airtox/to-11ar.pdf
EPA Compendium Method TO-17
https://www3.epa.gov/ttnamti1/files/ambient/airtox/to-17r.pdf
