Running at high pH Basic pharmaceuticals become neutral at high pH and exhibit significantly sharper analytical peaks and higher loadability. Higher loadability means higher productivity, leading to a much more economical purification process. With EternityXT, large- scale separations can be run for an extended time, even at levels as high as pH 12.
