主题:【求助】用EDTA滴定法测定溶液中的硫酸根浓度问题
Insm_188a0345
配置已知纯溶液硫酸钠90g/L。 EDTA是0.02mol/L  钡镁混合液是3g二水氯化钡和0.6g六水氯化镁溶于水并定容1L    铬黑T指示剂    缓冲溶液PH10
计算公式硫酸钠(g/L)=(V空-v1)*0.02*142.04/v样
空白滴定结果是14.9ml
取样0.5ml纯溶液硫酸钠,消耗 EDTA3.0ml  结果是67.6g/L
取样0.2ml纯溶液硫酸钠,消耗 EDTA8.5ml  结果是90.9g/L
取样0.3ml纯溶液硫酸钠,消耗 EDTA5.5ml  结果是89.0g/L
根据公式反推取样0.5ml纯溶液硫酸钠,在消耗EDTA0.00001ml也可以当没有时。得到的结果是84g/L。但是滴加一滴EDTA时,溶液没有变色,滴定消耗EDTA3ml时,溶液从酒红色变成蓝色。这是为什么。
TRANSLATE with  x
  English
ArabicHebrewPolish
BulgarianHindiPortuguese
CatalanHmong DawRomanian
Chinese SimplifiedHungarianRussian
Chinese TraditionalIndonesianSlovak
CzechItalianSlovenian
DanishJapaneseSpanish
DutchKlingonSwedish
EnglishKoreanThai
EstonianLatvianTurkish
FinnishLithuanianUkrainian
FrenchMalayUrdu
GermanMalteseVietnamese
GreekNorwegianWelsh
Haitian CreolePersian
TRANSLATE with
  COPY THE URL BELOW
  Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
哈希
哈希公司(HACH)
4008316616-1405
Insm_188a0345
