主题:【求助】交流阻抗中拟合用到Q,Q的两个参数值Y0和n各有什么意义?他们的变化能说明什么问题?
浏览0 回复5 电梯直达
amigo365
悬赏金额:20积分 状态: 未解决
交流阻抗中拟合用到常相角元件Q,Q的两个参数值Y0和n各有什么意义?他们的变化能说明什么问题?
amigo365
old fox
The impedance of a CPE has the form:
C=(1/Y0)(Jw)^n
When this equation describes a capacitor, the constant Y0 = C (the capacitance) and the exponent n = 1. For a constant phase element, the exponent n is less than one.
The "double layer capacitor" on real cells often behaves like a CPE instead of like a capacitor. Several theories have been proposed to account for the non-ideal behavior of the double layer but none has been universally accepted. In most cases, you can safely treat a as an empirical constant and not worry about its physical basis.
cystec
cystec
wchy1201
