Machine UP 2000 PK-4
Vertical, servo-hydraulic testing machine for static and dynamic applications
Range of application:
Precise, reproducible, demanding inspection tasks
Material and component testing
research and development
quality inspection
Test facilities:
structural engineering, building construction, civil engineering and bridge building
high-performance materials, prefabricated constructions
innovative load-bearing structures with different materials (e.g. hybrid constructions)
Application:
for a variety of different applications due to the flexible design
universal static, quasistatic, dynamic TENSION, COMPRESSION- and BENDING TEST according to accessories
vertical and horizontal load arrangement is possible
Fatigue and fracture mechanics tests are selected and offered from the wide range of possibilities for this series, depending on the customer's applications and test procedures.
