主题:【已应助】ASTM-E29 标准历史版本,希望大家帮忙,谢谢!
浏览0 回复2 电梯直达
冯亚超
求助ASTM-E29标准
近期在学习有效数字相关知识,需要了解ASTM-E29标准中有效数字修订历史,
但是只搜到三个历史版本(标红色部分),请论坛各位朋友帮忙,谢谢大家。
邮箱:fyc9964@163.com
ASTM E29-222022/4/1Standard Practice for Using Significant Digits in Test Data to  Determine Conformance with Specifications
ASTM  E29-13(2019)2019/1/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-132013/8/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-082008/10/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-06B2006/11/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-06A2006/9/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-062006/5/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-042004/12/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM  E29-02E12002/5/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM  E29-93A(1999)1999/5/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-93A1993/1/1Standard  Practice for Using Significant Digits in Test Data to Determine Conformance  with Specifications
ASTM E29-901990/1/1Standard  Practice for Using Digits in Test Data to Determine Conformance with  Specifications
ASTM  E29-67(1980)E11967/1/1Standard  Test Method for Indicating Which Places Of Figures Are To Be Considered  Significant In Specified Limiting Values
ASTM E29-671967/1/1Recommended  Practice For Indicating Which Places Of Figures Are To Be Considered  Significant In Specified Limiting Values
推荐答案:h04206010006回复于2022/10/08
https://www.instrument.com.cn/download/shtml/1098970.shtml
现行
您可能想找: 技术咨询 询底价
h04206010006
冯亚超
原文由 h04206010006(h04206010006) 发表:
现行
谢谢
