缩略语 | 英文名称 | 中文名称 |
AAA | amino acid analysis | 氨基酸分析 |
AAS | atomic absorption spectrophotometry | 原子吸收分光光度法 |
AED | atomic emission detection | 原子发射检测 |
AES | atomic emission spectrometry | 原子发射光谱 |
Auger electron spectroscopy | 俄歇电子能谱 |
AFS | atomic fluorescence spectrophotometry | 原子荧光分光光度计 |
amu | atomic mass unit | 原子质量单位 |
API | atmospheric-pressure ionization | 常压电离 |
AX/HPLC | anion-exchange HPLC | 阴离子交换搞笑液相色谱法 |
b.p.(bp) | boiling point | 沸点 |
CC | open(low pressure)column chromatography | 开口(低压)柱色谱法 |
CD | conductivity detection | 电导检测 |
circular dichrism | 圆二色性 |
CEC | capillary electrochromatography | 毛细管电色谱法 |
CF-FAB | continuous flow FAB | 持流快速原子轰击 |
CGC | capillary column gas chromatography | 毛细管柱气相色谱法 |
CI/MS | chemical ionization MS | 化学电离/质谱 |
CIA | capillary ion analysis | 毛细管离子分析 |
CLD | chemiluminescence detection | 化学发光检测 |
CLSE | column liquid-solid extraction | 液固柱萃取 |
13C NMR | carbon-13 NMR | 碳13核磁共振 |
CSFC | capillary supercritical-fluid chromatography | 毛细管超临界流体色谱法 |
CV | cyclic voltammetry | 循环伏安法 |
CX/HPLC | cation-exchange HPLC | 阳离子交换高效液相色谱法 |
CZE | capillary zone electrophoresis | 毛细管区域电泳 |
DAS | derivative absorption calorimetry | 导数吸收量热法 |
DNA | deoxyribonucleic acid | 脱氧核糖核酸 |
DSC | differential scanning calorimetry | 差热扫描量热法 |
DTA | differential thermal analysis | 差热分析 |
EC | electron capture detection | 电子捕获检测 |
ECD | electrochemical detection | 电化学检测 |
EELS | electron energy lose spectroscopy | 电子能量损失谱法 |
EI/MS | electron-impact MS | 电子碰撞质谱 |
EIA | enzyme immunoassay | 酶免疫测定 |
ELISA | enzyme-linked immunosorbent assay | 酶联免疫吸附测定 |
EMIT | enzyme-multiplied immunoassay | 酶多联免疫测定技术 |
emu | electromagnetic unit | 电磁单位 |
EPMA | electron-probe micro analysis | 电子探针微区分析 |
EPR | electron paramagnetic resonance | 电子顺磁共振 |
ESCA | electron spectroscopy for chemical analysis | 化学分析用电子能谱 |
ESR | electron spin resonance | 顺磁共振 |
FAB/MS | fast-atom-bombardment mass spectrometry | 块原子轰击质谱 |
FD | fluorescence detection | 荧光检测 |
FEM | method of field emission microscope | 场发射显微镜法 |
FIA | flow injection analysis | 流动注射分析 |
FID | flame ionization detection | 火焰离子化检测 |
f.p.(fp) | freezing point | 凝固点 |
FPD | flame photometric detection | 火焰光度检测 |
FPIA | fluorescence polarization immunoassay | 荧光偏振免疫测定 |
FT | Fourier transform | 傅里叶变换 |
FTD | flame thermionic detection(alkali flameionization) | 火焰热离子检测(碱火焰离子化) |
GC | gas chromatography | 气相色谱法 |
GC-MS | gas chromatography-mass spectrometry | 气相色谱-质谱联用(气质联用) |
GFC | gel filtration chromatography | 凝胶过滤色谱法 |
GLC | gas-liquid chromatography | 气-液色谱法 |
GPC | gel permeation chromatography | 凝胶渗透色谱法 |
GSC | gas-solid chromatography | 气固色谱法 |
HallECD | hall electrolytic conductivity detection | 霍尔电解质电导率检测 |
HME | hanging mercury electrode | 悬汞电极 |
1H NMR | proton NMR | 质子核磁共振 |
HPCE | high performance capillary electrophoresis | 高效毛细血管电泳法 |
HPLC | high performance liquid chromatography | 高效液相色谱法 |
μHPLC | microcolumn HPLC | 微径柱高效液相色谱 |
HPTLC | high performance TLC | 高效薄层色谱 |
HRGC | high resolution GC | 高分辨气相色谱 |
IC | ion chromatography | 离子色谱法 |
IE | indicated electrode | 指示电极 |
IE/HPLC | ion-exchang HPLC | 离子交换高效液相色谱 |
IEC | ion-exchange(low pressure)chromatography | 离子交换(低压)色谱法 |
ion-exclusion chromatography | 离子排斥色谱法 |
IEF | isoelectric focusing | 等点点聚焦 |
ILC | ion liquid chromatography | 离子液相色谱法 |
IMS | ion mobility spectrometer | 离子淌度光谱仪 |
IR | infrared spectrometry | 红外光谱法 |
ISE | ion-selective electrode | 离子选择性电极 |
LC | liquid chromatography | 液相色谱法 |
μLC | microcolumn LC | 微径柱液相色谱法 |
LC-MS | coupled HPLC-mass spectrometry | 高效液相色谱-质谱联用 |
LIFD | laser-induced fluorescence detection | 激光诱导荧光检测 |
LLE | liquid-liquid extraction | 液液萃取 |
LSC | liquid scintillation counting | 液滴闪烁计数 |
LSE | liquid-solid extraction | 液固萃取 |
MD | mass detection | 质量检测 |
MECC | micellar electrokinetic capillary chromatography | 胶束电动毛细管色谱法 |
MGC | multidimensional gas chromatography | 多维气相色谱法 |
MS | mass spectrum | 质谱 |
MSD | mass selective detection | 质量选择检测 |
NICI/MS | negative-ion CI/MS | 负离子化学电离/质谱 |
NCE | normal calomel electrode | 甘汞电极 |
NHE | normal hydrogen electrode | 标准氢电极 |
NMR | nuclear magnetic resonance | 核磁共振 |
NP/HPLC | normal-phase HPLC | 正相高效液相色谱 |
NPD | nitrogen phosphorous detection | 氮磷检测 |
PAD | pulsed-amperometric detection | 脉冲电流检测 |
PAGE | polyacrylamide gel electrophoresis | 聚丙烯酰胺凝胶电泳 |
PCR | post-column reaction(on-line) | 后柱反应(在线) |
PES | photo electron spectroscopy | 光电子能谱 |
PFGC | programmed flow gas chromatography | 程序变流气相色谱法 |
PI/HPLC | paired-ion HPLC | 离子对高效液相色谱法 |
缩略语 | 英文名称 | 中文名称 |
缩略语 | 英文名称 | 中文名称 |
缩略语 | 英文名称 | 中文名称 |
