主题:【分享】PmT DRO-4000系列介电谐振器振荡器
浏览0 回复0 电梯直达
Ins_53b266b9
特点:
可根据客户指定频率定制
封装MESFET或BJT器件
相位噪声低
低麦克风
高振动操作
SMT制作
内部调压
选型:
更多Princeton Microwave相关产品信息请访问立维创展ldteq.com
PmT    DRO
ParametersSpecifications
Model4000 Series4100 Series
Frequency Range3 to 12 GHz3 to 12 GHz
TuningMechanicalElectrical
Tuning Range,Min.±10 MHz±5 MHz
Power Output,Min.13 dBm13 dBm
Power Output,Max3 dB3 dB
Frequency Accuracy,Max.0.1%0.1%
Operating Temperature-50 to+100 ℃-50 to+100 ℃
Storage Temperature-55 to +125 ℃-55 to+125 ℃
Temperature Stability,Max.±0.05%±0.05%
Harmonics,Below Carrier,Max.-20 dBc-20 dBc
Spurious Output Below Carrier,Max.-60 dBc-60 dBc
Phase Noise
10 KHz offset
100 KHz offset
1 MHz offset
@10  GHz
-92 dBc/Hz
-115 dBc/Hz
-142 dBc/Hz
@10  GHz
-92 dBc/Hz
-115 dBc/Hz
-142 dBc/Hz
Input Voltage+15±0.5 VDC+15±0.5 VDC
Input Current,Max.75 mA75 mA
ConnectorSMA Female standardSMA Female standard
Weight,Max.3.0 oz3.0 oz.
SizeSee OutlineSee Outline
Order InformationPmT-DRO-4000 Series-
Frequency(GHz)
PmT-DRO-4100 Series-
Frequency (GHz)
您可能想找: 滤波器 询底价
猜你喜欢 最新推荐 热门推荐
