Materials Science and Engineering: R: Reports
Volume 17, Issue 2, 15 October 1996, Pages 57-103
http://www.sciencedirect.com/science?_ob=Art
ICleURL&_udi=B6TXH-3VXHM8W-2&_user=1021782&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000050479&_version=1&_urlVersion=0&_userid=1021782&md5=4304350649c7c2a2b702cb338bc87fa4
4.1.2. Maxwell-Wag,qer polarization
All ER suspensions possess some level of conductivity. Anderson [ 551 and Davis [45,56] have
pointed out that for d.c. and low-frequency a.c. electr
IC fields, part
ICle polarization and part
ICle
interactions will be ccntrolled not by the part
ICle and fluid permittivities as described above, but rather
by the part
ICle and fluid conductivities. Conductivity in the bulk of both phases will result in free The field external to the sphere is again equivalent to that of a dipole with moment
peff = $o~ca3 Re{ p *‘ei”e’}EOe,. (1%
The time-averaged force on a sphere at the origin due to a second sphere at (R, 19) may be determined
easily in the point-dipole limit as before,
FyD(Rij,eij) =&@T2f&f( o,)E&
4
; { [3 cos2 8,- l]e,+ [sin 20,]e,}, (16)
II
where ErmS - E,l fi, and the “effective relative polarizability” is now
where
Pd=
t =E
EP$2EC
,?NJ Oup + 2a;
(17)
(18)
The force is essentially equivalent to the ideal case except that the effective polarizability is now a
function of field frequency, as well as the permittivities and conductivities of both phases.
The value of Peff, and thus the pair force, depends on the frequency relative to the polarization
time constant t,,. In the limit of large frequencies, permittivities dominate the response,
lim P2ff(wJ = Pi (20) oer,rnv * m
while in the dc. limit,
and thus conductivities control part
ICle polarization forces, regardless of the permittivities. The nor-
malized polarization force magnitude, pzff, is plotted as a function of frequency in Fig. 4 for different
values of Pd and PC, As we will see below, this likely explains, qualitatively, why high dielectr
ICconstant materials such as barium titanate ( eP =@( 103) ) do not show a very large ER effect in d.c.
fields, and why many systems exhibit a decrease in apparent viscosity with increasing electr
IC field
frequency [ 3,4,8,62].
For part
ICles with a surface conductivity, h,, polarization and interactions in the point-dipole limit
are described by the Maxwell-Wagner model as described above, provided the part
ICle conductivity
is replaced by the apparent conductivity CT~ + 2&/a [ 9,571.
charge accumulation at the part
ICle/fluid interface-migration of free charges to the interface prompts
the alternative names, “migration” and “interfacial” polarization. In a d.c. field, mobile charges
accumulating at the interface screen the field within a part
ICle, and part
ICle polarization is completely
determined by conductivities. In a high-frequency a-c. field, mobile charges have insuff
ICient time to
respond, leading to polarization dominated solely by permittivities, unaffected by conductivities. At
intermediate frequencies, both permittivity and conductivity play a role.
The Maxwell-Wagner model (see, for instance, Refs. [57-611) is the simplest description of
part
ICle polarization accounting for both the part
ICle and fluid bulk conductivities, as well as their
permittivities. In this theory, the permittivities and conductivities of the individual phases are assumed
to be constants, independent of frequency. The complex dielectr
IC constants of the disperse and
continuous phases are written Q* ( w,) = ek -j( Us/ ~,,a,), where
IC =p,c, j = J-1, and the asterisks
represent complex quantities.
Consider again an isolated sphere in a uniform a.c. electr
IC field, E0 = Re{&&‘e,} . The complex
potential will still satisfy Laplace’s equation in the bulk phases [ 571, o”$* = 0, subject to the boundary
conditions at the interface,
$*i = v” (11)
The solution for the complex potential resembles that for the ideal case,
(12)
(13)
(14)
