Technical Library for LAMBDA 950/850/650 分光光度计资料
Applications and Use of Integrating Spheres With the LAMBDA 650 and 850 UV/Vis and LAMBDA 950 UV/Vis/NIR Spectrophotometers
The General Purpose Optical Bench (GPOB) for the LAMBDA 650 and 850 UV/Vis Spectrophotometers and LAMBDA 950 UV/Vis/NIR Spectrophotometer
Polarizer/Depolarizer Options for the LAMBDA 650 and 850 UV/Vis Spectrophotometers and LAMBDA 950 UV/Vis/NIR Spectrophotometer
Acquisition of High Quality Transmission Spectra of Ultra-Small Samples Using the LAMBDA 950 UV/Vis/NIR and LAMBDA 850 UV/Vis Spectrophotometers
Design Considerations for a Variable Angle Absolute Reflectance Accessory For the LAMBDA 950/850/650 UV/Vis/NIR and UV/Vis Spectrophotometers
UV650的相关资料
