Optical amplifiers - Test methods -- Part 10-2: Multichannel parameters - Pulse method using a gated optical spectrum analyzer 光学放大器---试验方法---第10-2部分: 多路参数---使用择通光谱分析仪的脉冲法 CLC/SR 86C 2008-01-31
EN 62246-2:2008
Reed contact units -- Part 2: Heavy-duty reed switches 簧片触点装置---第2部分:重型簧片开关 CLC/TC 94 2008-01-31
EN 50289-4-4:2008
Communication cables - Specifications for test methods -- Part 4-4: Environmental test methods - Resistance to solvents and contaminating fluids 通信电缆---试验方法规范---第4-4部分:环境试验方法---耐溶剂和耐污染流体 CLC/TC 46X 2008-01-31
EN 62311:2008 Assessment of electronic and electrical equipment related to human exposure restrictions for electromagnetic fields (0 Hz - 300 GHz) 人体耐暴露电磁场(0 Hz - 300 GHz)的电子电气设备的评定 CLC/TC 106X 2008-01-31 2006/95/EC, 1999/5/EC
EN 60601-2-37:2008 Medical electrical equipment -- Part 2-37: Particular requirements for the basic safety and essential performance of ultrasonic medical diagnostic and monitoring equipment 医用电气设备---第2-37部分:超声波医用诊断和监控设备的基本安全性和主要性能专门要求 CLC/TC 62 2008-01-31 93/42/EEC
EN 50289-4-5:2008 Communication cables - Specifications for test methods -- Part 4-5: Environmental test methods - Climatic sequence 通信电缆---试验方法规范---第4-5部分:环境试验方法---气候顺序 CLC/TC 46X 2008-01-31
CLC/TR 50456:2008 Alarm systems - Guidelines to achieving compliance with EC directives for equipment of alarm systems 报警系统---电子报警系统符合EC指令指南 CLC/TC 79 2008-01-25
EN 60584-3:2008 Thermocouples -- Part 3: Extension and compensating cables - Tolerances and identification system 热电偶---第3部分:外延和补偿缆线 ---公差和鉴定体系 CLC/SR 65B 2008-01-25
EN 62366:2008 Medical devices - Application of usability engineering to medical devices 医用设备---医用设备可用性工程的应用 CLC/TC 62 2008-01-25 93/42/EEC, 98/79/EC
EN 62353:2008 Medical electrical equipment - Recurrent test and test after repair of medical electrical equipment 医用电子设备---修理后的医用电子设备的重复试验和测试 CLC/TC 62 2008-01-25
EN 60641-1:2008 Specification for pressboard and presspaper for electrical purposes -- Part 1: Definitions and general requirements 电气目的用纸板和层压纸---第1部分: 定义和一般要求 CLC/SR 15 2008-01-24
EN 50482:2008 Instrument transformers - Three-phase inductive voltage transformers having Um up to 52 kV 工具变压器---电压为Um(=1.2kv) ~52 kV的三相感应电压变压器 CLC/TC 38X 2008-01-24
