Optima 7300 DV ICP-OES with Cyclonic Spray Chamber
N0770796
The Optima 7300 offers automatic duel viewing for the lowest detection limits and widest working ranges. Capable of analyzing large sample loads quickly, the 7300 is the ideal solution for laboratories with moderate to heavy loads of difficult samples.
Feature/Benefits:
• Ethernet communication protocols
o Simple and reliable
o Simplify accessory adoption
• New signal processors for each detector
o Faster data conversion (2X)
o Faster sample throughput
• Improved RF transistor cooling
o Better power efficiency
• Built in Intel processor running Windows CE
• Improved cover access for serviceability
• Universal Data Acquisition
o Retrospectively look at new wavelengths or elements not in method
o Small data size (75k)
• Detection limit run on demand automatically
o As QC or diagnostic
o Calculation parameters are user selectable
• Detailed calibration summary
o Reads back standard concentrations onto the calibration curve
o Excellent diagnostic tool; sometimes required by regulations
• Sample limit checks
o Flags unknowns when outside of desired concentration limits
o Range can be set by concentration value or percent variation
o Convenient tool for product QC checking
• QC Charting option
o Time charting of QC values
o Detection limit performance
• Method of Standard Additions
o Useful for difficult samples and complex matrices
o Useful when there is no blank material
o Traditional method
• Append method to autosampler run after run has begun
o Improved workflow efficiency
• Over Calibration Message
o Flags concentrations exceeding highest standard
o % over is user selectable
Optima 7300 DV ICP-OES资料下载:http://www.instrument.com.cn/download/search.asp?keywords=qzcp&sel=admin_name
