These pumps are useful for creating a high flow circulation, outside of a vessel. They are used for instance in some reaction, impregnation and dyeing processes, and when there is need of high external flow rate and/or a need of reheating/cooling, mixing, checking and modifying the composition or the properties of the fluid in a high-pressure reactor. Our pumps are driven by a magnetic seal-less motor, with no leak and contamination from outside; no dynamic sealing.
Typical standard flow rate range: 50 – 1,000 l/h
Flow rate variation possibilities with frequency variation
Pressure: 350 bar / 700 bar upon request
We also supply small centrifugal pump (30l/h, 700bar) for for option external recirculation of upper and lower phase. It allows faster mixing of the phases or pulsation-free feeding to an injection loop for online concentration measurements (HPLC, IR, etc.).
For more information, please contract FutureChemTech via www.futurechemtech.com.
