以下英语三小段落请大家翻译: As I know that your side is ordering IW1690-02 on TCL/Alcatel project and will use IW1692-30 for Samsung project.
For IW1690-02, you can see I had sent most of info. to you in before. For IW1692-30, do you want supplier to finish that same as IW1690-02 and fill in from 2.1 to 2.5. Pls double confirm this.
For IW1689, it is old part no. and all of customer had been replaced by IW1692 for new design. So, we assumed that it do not need to any RoHS info. on it. Pls double confirm that.
