不知道你有什么用,我也知道得不多,有些还是凭空猜出来的。还有一些就猜都猜不出来了。
*MEAS_MODE = CONTINUOUS:测量扫描模式:连续扫描,另一种是步进扫描(分定时计数和定数计时)
*TARGET = 29 这应当是靶的原子序数了,即Cu
*XRAY_CHAR = K-ALPHA1
*WAVE_LENGTH1 = 1.54056
*WAVE_LENGTH2 = 1.5444
**THICKNESS = 0, 0 厚度
*MU = 0, 0
*SCAN_MODE = 2theta/theta 扫描模式:2theta/theta,前者指计数器位置,后者指光管位置。仅样品转的称为theta,仅光管转的称为2Theta.
*SPEED_DIM = sec./step:扫描速度的度量单位:秒/步
*XUNIT = deg. X轴的的单位:度
*YUNIT = cps Y轴的单位:CPS,count per second
*SCALE_MODE = 1 扫描模式代码为1。下面的都是一些代码了,应当是重复前面用名称表示的东西
*REP_COUNT = 1 重复计数次数为1次。有时对于一个样品可以反复测量,将几次测量的数据进行叠加。这样强度高一些。
*SE_COUNT = 0 第二次测量否,应当是否。
*STD_MATERIAL = Unknown, Unknown, 0, 0, 0, 0, 0, 0
*LATT_CONS = 0, Unknown, Unknown, 0, 0, 0, 0, 0, 0
*SEC_COUNT = 1
*TSPEC_SIZE = 4
*TYPE_SPEC = 0, 0
*TYPE_SPEC = 1, 0
*TYPE_SPEC = 2, 0
*TYPE_SPEC = 3, 0
*MEMO =
*BEGIN
*GROUP = 0
*START = 10.0000
*STOP = 70.0000
*STEP = 0.0200
*OFFSET = 0.0000
*SPEED = 0.12
*SLIT_SPEC = 0, "1deg.", 1.74, 10
*SLIT_SPEC = 1, "1deg.", 0.94, 20 这里是狭缝
*SLIT_SPEC = 2, "0.3mm", 0.3, 20 同上
*KV = 40
*MA = 100
*LOW = 0 这里应当是指光管的电流和电压出错限制
*HIGH = 0
*CTEMPER = 0, 0 这里可能是对噪声的处理,有三个
*CTEMPER = 1, 0
*CTEMPER = 2, 0
*PAREX = 0, 0
*PAREX = 1, 0
*PAREX = 2, 0
*PAREX = 3, 0
*PAREX = 4, 0
*PAREX = 5, 0
*PAREX = 6, 0
*PAREX = 7, 0
*PAREX = 8, 0
*PAREX = 9, 0
*PAREX = 10, 0
*PAREX = 11, 0
*PAREX = 12, 0
*PAREX = 13, 10
*PAREX = 14, 0.01
*PAREX = 15, 0
*FULL_SCALE = 1000 这是绘图时的满刻度
*EXTRA_SIZE = 4
*EXTRA = 0, 0
*EXTRA = 1, 0
*EXTRA = 2, 0
*EXTRA = 3, 0
*INDEX = 0, 0, 0
该帖子作者被版主
chemsay加 2积分,
2经验,加分理由:谢谢黄老师
