主题:【原创】已经亲自测定了某奶粉中的三聚氰胺,参考FDA方法(已追贴结果)
浏览0 回复30 电梯直达
wbp
经过数天的努力,我已经亲自测定了某奶粉中的三聚氰胺,参考采用FDA方法见附件,结果检出了三聚氰胺,回收做到77%。采用设备:ABI 3200 串联质谱仪
点评:采用苯基柱对三聚氰胺有较好保留,标准曲线配制10-200ppb。检出限约为0.1mg/Kg。
还将做进一步方法改进:买的内标——苯代三聚氰胺 刚到,准备下一步改为内标法。
欢迎大家跟帖讨论交流。
FDAよ猭
sharkwein
Laboratory Information Bulletin  LIB No. 4396 Volume 23, May 2007Determination of Melamine Residues in Catfish Tissue by Triple Quadrupole LC-MS-MS with HILIC ChromatographyWendy C. Andersen, Sherri B. Turnipseed, Christine M. Karbiwnyk, and Mark R. MadsonU.S. Food and Drug Administration, Animal Drugs Research Center, Denver, CO
ABSTRACTA triple quadrupole liquid chromatography tandem mass spectrometry method is presented for the quantitative determination and confirmation of melamine residues in catfish. Catfish tissue was extracted with 50:50 acetonitrile:water and 1 N hydrochloric acid and cleaned-up using Oasis® MCX solid phase extraction cartridges. Extracts were analyzed by LC-MS-MS with HILIC chromatography and electrospray ionization in positive ion mode. The precursor ion for melamine is m/z 127. Two product ion transitions were monitored at m/z 85 and 68 for quantification and confirmation. Catfish tissue was fortified at 10, 25, 50, 100, and 500 ng/g (ppb). The average recovery of melamine from fortified samples (n = 17) was 76.3 % with an RSD of 14.3 %.
效果跟原方法差不多哦,楼主在哪里的?可以接受委托检测不?
xhdhy1982
国家已经发布了三聚氰胺的检测方法,大家可以找找
郁金香
coool11
泳儿
nnsss
denkenlj
roland2008
linuschen
bennyheqm
