主题:【求助】二硫代氨基甲酸酯类农残可以用GC-MS检测吗?
浏览0 回复10 电梯直达
yangmei
二硫代氨基甲酸酯类农残,如代森锰锌,福美双等可以用GC-MS检测吗?查了方法,可以用气相做的,是以二硫化碳计算的,还有滴定法。哪位有做过,给点建议,谢谢!
您可能想找: 气质联用(GC-MS) 询底价
戈壁明珠
realtiger
水番
原文由 zongguitang 发表:
我用气相的顶空做过,效果还行。气质法没有做过。
您好,您用气相做用的是什么检测器?响应值高吗?谢谢!
雾非雾
原文由 lnyangmei 发表:
以二硫化碳或是滴定法做的,检测限都比较高,满足不了0.01的要求的.代森锰锌,福美双都要用单独法做前处理吧.
yangmei
原文由 realtiger 发表:
这种农药气相很不好做
除了用气相,那还能用什么方法来做?滴定法或分光光度计法?
我在故我思
2.2 For Mancozeb in Water
An 8 mL portion of sample was placed into a 40 mL vial along with 10% EDTA, and 3% nCl2/8N HCl solution and capped. The samples were placed in a heating block at 100℃for four hours with shaking at various time intervals. The samples were then analyzed by GC/MSD
using SIM.
附件
附件:
我在故我思
福美双(thiram)可以用液相方法做:
Determination of tetramethylthiuram disulfide (Thiram) in river water by high-performance liquid chromatography: Micellar versus conventional reversed phase chromatography
Summary:
After a comparative study of conventional reversed phase and micellar liquid chromatography a method is described for the determination of the fungicide thiram in river water based on the use of micelles of CTAB. The method involves the extraction/concentration of thiram with a C18 cartridge followed by separation on a C18 reversed-phase column with a mobile phase of 20% (v/v) acetonitrile/0.01 M CTAB in phosphate buffer (pH-6.3), and detection at 254 nm. The method allows the determination of thiram in the presence of other water-soluble dithiocarbamate fungicides (nabam, ziram and ferbam) with a limit of detection of 36 pg mL–1 for a typical 20-fold preconcentration.
全文:
附件
附件:
yangmei
l_xh
rzxjz
