原文由 redanqi 发表:原文由 redanqi 发表:
6.3.2.5 Sampling, extraction and gravimetric analysis for phthalate plasticisers
Place the sample in a pre-weighed 150 ml flat bottomed flask and heat in an oven at (105 ± 5) °C for (30 ± 5) min. Allow to cool in a desiccator. Weigh the flask and sample. Use a scalpel or other appropriate cutting utensils to cut a representative portion from the sample into small pieces (< 5 mm Ø). Weigh accurately (2 ± 0,2) g of the pieces into a Soxhlet thimble and add cotton wool to the top of the thimble.
Add approximately (50 ± 10) ml of diethyl ether into the flask. Reflux gently for 6 h ± 30 min. Allow sufficient time for the diethyl ether to cool. Completely evaporate the diethyl ether by means of a steam bath. Place the flask in an oven at (105 ± 5) °C for (30 ± 5) min. Allow to cool in a desiccator and weigh. Repeat the drying and cooling cycles until the difference between two consecutive weighings are not more than 0,0005 g. A blank solution shall be run consecutively.
6.3.2.5邻苯二甲酸酯类的取样、浸提和重量分析
同法制备空白溶液。
是邻苯二甲酸增塑剂的取样、浸提和重量分析吧
A blank solution shall be run consecutively 空白溶液同法制备,还是连续跑几次?
run可以翻译为制备吗?
原文由 sin2008 发表:原文由 redanqi 发表:原文由 redanqi 发表:
同法制备空白溶液。
run可以翻译为制备吗?
楼主翻译的还是不错的,run应该在这里是进行操作,引伸一下就是制备了。
原文由 redanqi 发表:
Where appropriate from the stock standard solutions prepare two sets of five phthalate esters GC-MS calibration solutions in n-Hexane to the maximum linear concentration shown in Table 4 (Calibration Set 1), and Table 5 (Calibration Set 2).
分别用各邻苯二甲酸酯类的标准储备液制备2套GC-MS测试用标定溶液,每套5个浓度成线性关系,其最大线性浓度见表4(标定浓度1)及表5(标定浓度2)。
Where appropriate from the stock 啥意思?语法上看不懂
这个好像要整个句子看比较好,Where appropriate from the stock standard solutions 这个应该作为下面那个prepare 动作的条件。不知道这样看正确不?
原文由 redanqi 发表:
run可以翻译为制备吗?
原文由 hyheying 发表:原文由 redanqi 发表:
run可以翻译为制备吗?
原文由 redanqi 发表:原文由 hyheying 发表:原文由 redanqi 发表:
run可以翻译为制备吗?
实际操作室这样的吗?
我翻译进针的有点度偶,看到这个run和blank solution总认为是进针的意思
