Hall-Heroult process for aluminum production
"heavy-duty" cell (battery)
Helmholtz layer
see electrochemical double layer
Heyrovsky and polarography
history of electrochemistry
Jaroslav Heyrovsky and polarography
Volta and the "Pile"
hydrogen
production from non-terrestrial resources
production in brine electrolysis
hypochlorite production
industrial organic electroshyntesis
insect damage, electrochemical response in plants
intergranular corrosion
iron
lead
electrolytic production
electrolytic refining
Leclanche cell (battery)
lithium cell (battery)
load leveling
using electrochemical capacitors
machining, eletrochemical
magnesium-manganese dioxide cell (battery)
magnetic effects in electrochemistry
Mars, resource processing
membrane cell
use in brine electrolysis
mercury cell
nonrechargeable cell (battery)
metal deposition
see electroplating
metal oxide films
anodic
metal plating
see electroplating
metal production
aluminum
cadmium
cobalt
copper
gold
lead
molybdenum
nickel
platinum
silver
zinc
metal refining
copper
lead
nickel
silver
mixing
effect of magnetic field
molybdenum
production
Moon, resource processing
nanotechnology
aluminum oxide films as templates in
nickel
niobium
anodic oxide films on
anodizing
use in electrolytic capacitors
noneletrochemists, electrochemistry for
non-terrestrial resource processing
nylon, electrolytic production of precursor (adiponitrile)
organic compounds, electrolytic production
oxide films
anodic
oxygen
passivation
perchlorate production
pile, voltaic
pitting corrosion
plant life, electrochemistry of
polarography
platinum
production
polishing, eletrochemical
pollution abatement
pseudocapacitance
in electrochemical capacitors
porous anodic oxide films
recycling
robotics
sensor array
in the electrochemical nose
shaping, eletrochemical
silicon
silver
production
silver oxide cell (battery)
smart implants
smell
sodium chlorate production
sodium hydroxide production
sodium hypochlorite production
soil remediation
sulfide ores, metal winning from
smoothing, eletrochemical
supercapacitor
see electrochemical capacitor
tantalum
anodizing
taste
titanium
anodizing
tungsten
anodizing
ultracapacitor
uniform corrosion
Volta, Alessandro
Voltaic pile
waste treatment
water disinfection
zinc
zinc-air (oxygen) cell (battery)
zinc-manganese dioxide cell (battery)
zinc-mercury oxide cell (battery)
zinc-silver oxide cell (battery)
zirconium
anodizing
The Encyclopedia is hosted by the Ernest B. Yeager Center for Electrochemical Sciences (YCES) and the Chemical Engineering Department, Case Western Reserve University , Cleveland, Ohio.
Copyright Notice.
Edited by Zoltan Nagy (nagy@anl.gov) The Center for Electrochemical Science and Engineering and Department of Chemical and Environmental Engineering, Illinois Institute of Technology, Chicago, Illinois.
