主题:【分享】激光处理后的白炽灯更亮!
浏览0 回复8 电梯直达
atlas
美国罗彻斯特大学的光学研究者们已经开发出了一种激光加工工艺,可以使常规100W白炽灯消耗的电能低于60W白炽灯,而发出的光却具有同样的亮度。这种加工工艺使用超强功率的激光,能够在白炽灯内部常规钨丝的表面制造出一种独特的纳米和微米级结构,从而使钨丝辐射光的效率更高。新的超级钨丝采用超短和超强的被称之为飞秒激光脉冲的光束加工,光束仅持续千万亿分之几秒。
罗彻斯特大学的光学副教授郭春雷表示,他的光学小组正在金属表面上用超快速激光脉冲进行试验,而且还要测试激光作用在钨丝上的效果。通过发射激光束透过灯泡的玻璃,实验小组发现,灯泡上的小部分面积的亮度发生了改变,但在发光时它所消耗的能量却没有变化。
atlas
An ultra-powerful laser can turn regular incandescent light bulbs into power-sippers, say optics researchers at the University of Rochester. The process could make a light as bright as a 100-watt bulb consume less electricity than a 60-watt bulb while remaining far cheaper and radiating a more pleasant light than a fluorescent bulb can.
The laser process creates a unique array of nano- and micro-scale structures on the surface of a regular tungsten filament—the tiny wire inside a light bulb—and theses structures make the tungsten become far more effective at radiating light.
The findings will be published in an upcoming issue of the journal Physical Review Letters.
"We've been experimenting with the way ultra-fast lasers change metals, and we wondered what would happen if we trained the laser on a filament," says Chunlei Guo, associate professor of optics at the University of Rochester. "We fired the laser beam right through the glass of the bulb and altered a small area on the filament. When we lit the bulb, we could actually see this one patch was clearly brighter than the rest of the filament, but there was no change in the bulb's energy usage."
The key to creating the super-filament is an ultra-brief, ultra-intense beam of light called a femtosecond laser pulse. The laser burst lasts only a few quadrillionths of a second. To get a grasp of that kind of speed, consider that a femtosecond is to a second what a second is to about 32 million years. During its brief burst, Guo's laser unleashes as much power as the entire grid of North America onto a spot the size of a needle point. That intense blast forces the surface of the metal to form nanostructures and microstructures that dramatically alter how efficiently light can radiate from the filament.
In 2006, Guo and his assistant, Anatoliy Vorobyev, used a similar laser process to turn any metal pitch black. The surface structures created on the metal were incredibly effective at capturing incoming radiation, such as light.
"There is a very interesting 'take more, give more' law in nature governing the amount of light going in and coming out of a material," says Guo. Since the black metal was extremely good at absorbing light, he and Vorobyev set out to study the reverse process—that the blackened filament would radiate light more effectively as well.
"We knew it should work in theory," says Guo, "but we were still surprised when we turned up the power on this bulb and saw just how much brighter the processed spot was."
In addition to increasing the brightness of a bulb, Guo's process can be used to tune the color of the light as well. In 2008, his team used a similar process to change the color of nearly any metal to blue, golden, and gray, in addition to the black he'd already accomplished. Guo and Vorobyev used that knowledge of how to control the size and shape of the nanostructures—and thus what colors of light those structures absorb and radiate—to change the amount of each wavelength of light the tungsten filament radiates. Though Guo cannot yet make a simple bulb shine pure blue, for instance, he can change the overall radiated spectrum so that the tungsten, which normally radiates a yellowish light, could radiate a more purely white light.
Guo's team has even been able to make a filament radiate partially polarized light, which until now has been impossible to do without special filters that reduce the bulb's efficiency. By creating nanostructures in tight, parallel rows, some light that emits from the filament becomes polarized.
The team is now working to discover what other aspects of a common light bulb they might be able to control. Fortunately, despite the incredible intensity involved, the femtosecond laser can be powered by a simple wall outlet, meaning that when the process is refined, implementing it to augment regular light bulbs should be relatively simple.
symmacros
atlas
原文由 jimzhu 发表:
是个节约能源的好办法。
原理难琢磨!
江边一只鸟
hhhmonkey
当物体的形貌达到微米或者纳米尺度时,发光特性会改变,一般尺度越小就会向蓝光波段发生移动。发光轻度也会相应的变化
qinyueyang
atlas
从报道中看出,是灯泡制成后用激光处理的,效果真的明显吗?如了解了其中的机理,可在灯丝制造过程中增加激光处理工序。
莞城.XiShui
