主题:【求助】(ok)求英文文献1篇:MESHING THEORY AND SIMULATION OF NONINVOLUTE BEVELOID GEARS WITH CROSSED AXES
浏览0 回复2 电梯直达
goodlucktous
文献标题:MESHING THEORY AND SIMULATION OF NONINVOLUTE BEVELOID GEARS WITH CROSSED AXES
摘要:Based on the space engagement theory, a special type of noninvolute beveloid gears meshing with line contact between crossed axes has been studied in this paper. The engagement equation and tooth profile equation have been presented by applying the theory of gearing. Meanwhile the tooth profile errors and axial errors have been calculated by means of numerical analysis in this paper. The changes of these errors and the main factors have been studied. As a numerical example, the three-dimensional simulation of beveloid gears between crossed axes has been finished by means of the CAD system, Pro/Engineer. A new way of gear tooth modification is developed based on the space engagement theory for the first time in this paper. By improving the wheel gear grinder of large plane grinding, the paper has provided the tooth modification method of manufacturing noninvolute beveloid gears meshing with line contact between crossed axes. Finally, an example and its calculation results are presented.
作 者: Guangbin YuYuxiang ShiWei WangGuixian Li
母体文献: 2007 ASME International Design Engineering Technical Conferences and Computers and Information in Engineering Conference (DETC 2007)
会议名称:
会议时间: 2007年01月01日
会议地点: Las Vegas, Nevada, USA
求全文文献,谢谢!
灰米奇
大陆
