主题:【求助】P-T-X
regedit88888
This book covers the thermodynamic foundations of inorganic materials science and the controlled synthesis of inorganic materials. A new thermodynamic approach to the non-stoichiometry of crystalline solidsknown as vapor pressure scanning, has been developed by the author and is described in detail in this book. It is based on the high-precision experimental determination of the boundaries of the single-phase volume of the solid in the pressure-temperature-composition P-T-X phase space. This approach has been tested on a number of inorganic materials and has been shown to have an unparalleled precision (up to 10-4 at.%) in the determination of non-stoichiometry directly at high temperatures (up to 1200?C). Along with the results obtained by the author and his colleagues, the P-T-X diagrams of other important materials (e.g., III-V, IV-VI semiconductors) are also discussed.
请帮助解释以上文字中的专业术语
vapor pressure scanning是一种什么扫描手段
tutm
vapor pressure scanning 从文字看就是这本书里介绍的一种热力学新方法,没见过。
pressure-temperature-composition P-T-X phase space,是压力(强)、温度、化学组分三者组成的相空间,具体用P-T-X相图表示三者的关系,这是决定物质存在状态的基本热力学参数。上面介绍的方法好像就是用于测试相图中固相边界的。
手机版: 【求助】P-T-X
