原文由 poorlittle(poorlittle) 发表:
原文由 hexiaofei(hexiaofei) 发表:
感谢好心人的回答,可是我还是不明白“inaccessible component”到底需不需要符合“standard”
I do not really understand your question. In general or in common sense, all “components” shall comply with the relevant “standard”.
May I suggest you to clearly identify your problem first. It is said that properly identifying the problem will solve 50% of the problem.
我的疑问是要求accessible 和inaccessible部分都不要超标 还是说仅仅针对inaccessible的部分?
该句子没有提到accessible部分应该怎样 但是按常理来说 可接触到的肯定不能是有害物质啊
banned hazardous substance 在该法案里面除了有文字的定义以外 还有一些LIMITATION
