我用的是Nicolet-5700红外光谱仪,今天开机,稳定仪器一个小时后,在电脑上点红外软件,报错显示:The optical bench parameters are not appropriate for the current configuration and were not loaded. 强制进去后,点击Experiment setup 点bench 发现界面和以前不一样,又报错显示:The selected detector is not in the bench configuration. A different detector will be selected.
