主题:【分享】重新再学一遍 : Numerical Values
浏览0 回复12 电梯直达
poorlittle
最近, 发觉自己对一些基本概念其实不很明白, 要从新再学一遍了。  以下是学习後的一些记录:
Numerical Values
There are three different kinds of numerical values:
(a)  Exact (精确) terminating values : These are expressed to as many figures as are required to give the complete values, without approximation or uncertainty.
Example 1 : 1 inch = 25.4 mm; 25.4 is an exact value 基于国际公认
Example 2 : interest rate = 1.3%; 1.3% is an exact value 基于协议
Example 3 : I have 10 fingers; 10 is an exact value
基于准确点算
(b)  Inexact decimal expressions for exactly defined numbers : These numbers can be expressed with any desired accuracy by taking sufficient figures.  Many values having a purely mathematical basis fall into this category.
Example 4 : 1/3,  e, π
(c)  Inexact (非精确) values : Figures which are subject to inherent limitations of accuracy.  Experimentally determined values fall into this category.
Example 5 : The steel rod is 132.2 mm; 132.2 is an inexact value as the length may be 132.23 mm if a more precise instrument was used in the measurement.
Because of the uncertainty of inexact values, there are rules of arithmetic operation for the inexact values with reference to their number of significant figures.
Example 6 : 11111.111 + 1.1 = 11112.2  (1 decimal place)
Example 7 : 11111.111 × 2.2 = 24444.4442 = 2.4 × 104 (2 significant figures)
However, these rules are not applicable to the arithmetic operation of exact values, 不能胡乱套用。
(正在想, 测试标准中的极限数值, 或称界限值, 是否Exact value)
影子
有些概念确实需要好好学习,常常以为自己很明白,可是当给别人解释的时候才知道自己原来只是一知半解
poorlittle
同感。
  以上资料我十年前已看过, 现在重新再学一遍, 又有新体会。
Why the concept of Exact Value and Inexact Value is important?  Here is my experience:
I know that the average of 0.13, 0.25, 0.19, 0.32,0.41 is
(0.13+0.25+0.19+0.32+0.41)/5=0.26
I would not report that the average = 0.3 by taking into account of the number of significant figure of 5 (i.e. n.s.f.=1 for the number 5), but I did not know the reason in the past.  Now, I know that 5 is an exact value, so the rules of arithmetic operation for significant figures do not apply.
(There is another opinion that although 5 is an exact value, if the concept of significant figure must be imposed on it, 5 has infinite number of significant figures, i.e. 5=5.0000……00000)
I am thinking whether the limiting value (极限值, 或称界限值) specified in the testing standard is an exact value.  If it is an exact value, I need not consider the number of significant values when I report the measured value, only consider the precision as indicated by the limiting value.
: 极限值=0.030%, 测定值=0.1573%
My opinion:
(1)  不认为0.030%是一个有2位有效数字的数, because it is an exact value
(2)  0.030%显示了精度要求为千分位
Therefore:
(A)  我不会报0.16%, 這会損失精度, 亦与有效数字的概念无关(see (1) above)
(B)  我也不会报0.1573%, 这会太长而无助于判定是否合格
我会报0.157%
2010/6/11 15:53:09 Last edit by poorlittle
闲鹤野云
poorlittle
Inexact value significant figure, I think that significant figure is one of the attributes of inexact value.  I am still studying this subject and unable make the precise definitions for them.  Perhaps, the following example may illustrate their difference:
If the population of a city is 1.030×106 in government survey record and when it is printed as 1030000 in the newspaper, I would have the following description about the value 1030000:
1030000 is an inexact value (人口统计时是以千为单位的, 不会精确至几百几十的)
1030000 是一个7位数
1030000 具有4位有效数字
1030000 1,0,3,0 是有效数字, 最右的三个0是定位0
我似乎在鑽牛角尖, 但我的工作之一是计量, 对一些有关数字的基本概念不能不理啊。
2010/6/24 9:59:24 Last edit by poorlittle
happy王子矜
最近要新写一个关于修约的SOP,有两个参考,一个是国标,注重有效数字,标准多少有效数字就多少位数(我们以前就这么干);一个是国外某企业的SOP,注重仪器和方法本身的精度,打算倾向后者。但是这么写的话,又牵涉到仪器方法的相关SOP里面的内容,工程比较大。犹豫不决中。
影子
原文由 王蒹葭(wangzijin) 发表:
以我的经验,可以在这个修约的SOP中用一句话规定:所有修约的程序以本SOP为准。
仪器方法的相关SOP以后再逐步修订。
poorlittle
标准多少有效数字就多少位数?
The problem is how do you interpret “”.  In the past month, I studied the “significant figure” again and found that there are two meanings of “”, i.e. number and place.  Example:
(A)  0.00235 : 3有效数字 (number of significant figures = 3)
(B)  0.00235 : 精确至小数後5 (5 decimal places)
http://bbs.instrument.com.cn/shtml/20100608/2599734/ 中提到药典明确规定了结果的有效位数要和标准一致啊!!”,  这个位数要和标准一致中的位数应是(B)“place”.  If this interpretation is accepted, there is no difference between 国标 and 国外某企业的SOP(GB/T 8170-2008 Clause 4.3.3.1中用的字是数位一致, my interpretation is “in agreement with the places of the limiting value”)
I am writing a notes about the Significant Figure, and really really want to know the exact wording in 中国药典
My suggestion to your SOP about rounding is “the rounding of the measured value should be in agreement with the limiting value” 轻轻带过, 留有演译的余地;
or more specific “the rounding of the measured value should be in agreement with the places of the limiting value” so as to be in line with GB/T 8170-2008 Clause 4.3.3.1
or “in accordance with xxxxxx unless otherwise specified”
happy王子矜
恩,谢谢微寒老师的建议。其实我现在面对的与其说是数字的修约问题,不如说是数据报告习惯的问题。除了对外的药品企业外,我看到的一般情况就是,仪器检测出多少数据就是多少。比如,一个液相检测杂质报告0.0005%,实际情况是,这个仪器或方法根本没有这样的检出限,但是如果你报告<0.01%(假设检出限是0.01%),领导就不认可。非得让你写个确切的数字。
我们现在的规定是:按照有效数字的位数,检测标准有多少位,结果就报告多少位,如果有100%或0的情况,就往下多保留一位,直至不为100%或0为止.没提检出限这回事。
另:微寒老师的论坛内另外个帖子的链接,我的google浏览器打开后,每次点关闭这个页面,浏览器就崩溃一次。
2010/6/24 14:14:36 Last edit by wangzijin
poorlittle
A quantitative result sometimes or to some extent would become a qualitative indication
领导要照顾一些非专业客户(或专业客户的非专业领导), 让报告填上数字, 令报告看起来有根有据, 亦无可厚非。  行内人会明白, any value below the detection limit is only an indication.  An indication of 非常非常少的杂质。
( “飞流直下三千尺”, 这个三千不是真的quantitative value of 3000, but a qualitative indication of 高。  所以, 能科学地出一份报告固然好, 若要报一个小于检出限的数值作为indication, 也不是不能自园其说的。)
happy王子矜
因为能自圆其说,所以才能坚持这么久啊。还好我是另起炉灶,不然的话还要担心伤及领导颜面的问题,哈哈。
我初步打算严格按照仪器/方法的检出限出报告了,这样被客户审计的时候轻松点。至于领导不满意就不管了,现在没有直接领导关系了。
其实,也不能说我们的客户不专业,就我的观察,日本人比较喜欢你有多少位就写多少位,一个GC方法堂而皇之的写个位数的ppm结果,欧美客户更喜欢检出限之外的就报<xxx
2010/6/24 23:18:03 Last edit by wangzijin
