主题:【转帖】欧盟拟将六种SVHC物质列入REACH法规附件XIV(需授权物质清单)
浏览0 回复6 电梯直达
智慧的弟弟
2010年6月30日,欧盟向WTO发布通报(通报号G/TBT/N/EEC/337),拟将以下六种物质列入REACH法规附件XIV(需授权物质清单)中,分别是:二甲苯麝香(musk xylene)、六溴环十二烷(HBCDD)、4,4’-二氨基二苯基甲烷(MDA)、邻苯二甲酸二(2-乙基己醇)酯(DEHP)、邻苯二甲酸丁卞酯(BBP)、邻苯二甲酸二丁酯(DBP)。这六种物质也是欧盟发布的第一批SVHC物质。而一旦被列入附件XIV中,则在“日落之日”前,每种物质需要申请授权方可投放欧盟市场。
信息来源:技术壁垒资源网
您可能想找: 激光拉曼光谱(RAMAN) 询底价
无名
无名
ECHA's draft recommendation of priority substances for inclusion in the list of substances subject to authorisation
The draft recommendation consists of an overview table describing the draft entries to be inserted in Annex XIV (this table is available here) and the substance specific specification documents providing the specification for each recommended entry in Annex XIV. These specification documents have been prepared on the basis of substance specific background documents developed by ECHA. (see table below for links to the specification documents and to the background documents).
Interested parties are invited to submit comments on the draft recommendation and its reasoning by 30 September 2010, in particular on uses which should be exempted from the authorisation requirement. For commenting, the forms provided in the table below must be used.
An outline of the general approach used to develop the draft recommendation is available below under "further information".
Note: The consultation is subject to data privacy rules available below under "further information". In general ECHA may publish all comments and information received on its website. However interested parties can also submit confidential information, which will only be made available to ECHA, including its Committees, and the Commission. In that case a specification must be given by the submitting party as to why the information submitted is considered confidential. Detailed instructions on how to submit confidential information is provided in the commenting form.
Substance identification  Date of publication  Deadline for commenting  Link to the specification document  Link to the background document  Link to commenting form
Substance name  EC number  CAS number
2,4 – Dinitrotoluene (2,4-DNT) 204-450-0 121-14-2 01/07/2010 30/09/2010      Submit information
Diarsenic pentaoxide 215-116-9 1303-28-2 01/07/2010 30/09/2010      Submit information
Diarsenic trioxide  215-481-4 1327-53-3 01/07/2010 30/09/2010      Submit information
Diisobutyl phthalate (DIBP) 201-553-2 84-69-5 01/07/2010 30/09/2010      Submit information
Lead chromate 231-846-0 7758-97-6 01/07/2010 30/09/2010      Submit information
Lead chromate molybdate sulfate red (C.I. Pigment Red 104) 235-759-9 12656-85-8 01/07/2010 30/09/2010      Submit information
Lead sulfochromate yellow (C.I. Pigment Yellow 34) 215-693-7 1344-37-2 01/07/2010 30/09/2010      Submit information
Tris (2-chloroethyl) phosphate (TCEP) 204-118-5 115-96-8 01/07/2010 30/09/2010      Submit information
智慧的弟弟
智慧的弟弟
原文由 璞琇-环保兄(lotus_sum) 发表:
我看到的原文怎么是八个呢?
你说的八种是这个:http://bbs.instrument.com.cn/shtml/20100702/2643867/
7月1日披露的
我发这个是6月30日披露的
shuirukong
999youran
